what size cat?
Old Feb 21, 2005 | 08:41 PM
Jaisun's Avatar
New User
Default what size cat?
Picking up a jun 421 header, anybody know what size cat i need to bolt right up to tanabe rm.
thanks
Old Feb 21, 2005 | 08:54 PM
chero112's Avatar
Default Re: what size cat? (Jaisun)
what car is it for? what motor do you have also what year motor?
Old Feb 23, 2005 | 11:18 PM
Jaisun's Avatar
New User
Default Re: what size cat? (chero112)
oh sorry.. it is a 96 GSR with a B18c... thanks
Old Feb 24, 2005 | 03:27 AM
Takumi Fujiwara's Avatar
what size collector is on the Jun header? And what size piping is your exhaust. This should be the factors that help you decide what size cat you need....
Old Feb 24, 2005 | 03:06 PM
chero112's Avatar
Default Re: what size cat? (Takumi Fujiwara)
well if you get a high flow get or either a test pie it well be 13 to 14 inches because your year integra which is 96 the header's are made a bit longer..... Not really sure But I'm thinking it's 13 inches.......
Old Feb 24, 2005 | 07:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chero112 &raquo;</TD></TR><TR><TD CLASS="quote">well if you get a high flow get or either a test pie it well be 13 to 14 inches because your year integra which is 96 the header's are made a bit longer..... Not really sure But I'm thinking it's 13 inches.......</TD></TR></TABLE>
I was actually referring to piping diameter. But since we're on this length subject, if the jun header is made for a 94-99 USDM GSR, you'll need the stock length cat. The diameter of the cat inlet & outlet will depend on your piping diameters of your header collector and cat-back. I would advise you to keep your piping the same size or step up as you go back. Remember that cats are measured in inner diameter while the collector and cat-backs are measured in outer diameter.
Old Feb 25, 2005 | 12:02 AM
LiL MaN213's Avatar
B A N N E D
if u want i got a high flow cat for sale just im me when u get this LiLMaN21369 and well talk
Old Feb 25, 2005 | 12:04 AM
dawalude's Avatar
should be 2.5" OD with that setup
CRXified
Mar 13, 2006 12:57 AM
s0ulless
Oct 12, 2004 05:11 PM
GsRedTeg
Sep 20, 2004 09:50 PM
EGsixer
Jan 30, 2003 02:40 PM
