Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Auto-X Custom Welded Roll Cage (Simple Questions) Please Help
Old Feb 21, 2005 | 08:35 PM
NinetyTwoHB's Avatar
Default Auto-X Custom Welded Roll Cage (Simple Questions) Please Help
Hey...
I've been researching all sorts of roll cages until now. I have finally come up with the idea of welding up my own. I have a few simple rules...(BUT first off, i have researched this topic)
ALSO... i have read both NASA and SCCA rulebooks. These questions are referred to the rules.
I WANTED TO KNOW:
1) The minimum size for my wight class is 1.5 x .9.....im thinking about .120, but what about tube diameter...1.75??maybe?
Thank you for your time in advance...also i will greatly appreciate it if people can keep there useless comments out... because i just want quick answers from different people.
THANKS AGAIN
-Areg
Modified by NinetyTwoHB at 2:39 PM 2/24/2005
Old Feb 21, 2005 | 08:38 PM
davidnyc's Avatar
Default Re: Auto-X Custom Welded Roll Cage (Simple Questions) Please Help (NinetyTwoHB)
Do you plan on doing track events (HPDE's or Time Trials) or mainly autox? Usually a roll-cage is over kill for autocross.
Old Feb 22, 2005 | 08:09 AM
mikeski38's Avatar
Default Re: Auto-X Custom Welded Roll Cage (davidnyc)
For a 92 civic, 1.5" x .095 is legal, but most of the time you have to ballast those cars to get them to meet min weight anyway, so I prefer to use 1.5" x .120 tubing for this application.
No, you don't need a certified welder to pass tech, but the tech guys are getting MUCH more thurough with their inspections so your guy had better be good or you may find yourself doing it again.
Building cages is not rocket science, but there are a few little tricks that make the difference between a good cage, and a cage that you will find yourself cutting out in a few months. So I would make sure you know what you are getting into. I would recommend spectating at a local SCCA or NASA race event to get some ideas before you start. Good luck!
Old Feb 22, 2005 | 08:44 AM
r2x's Avatar
r2x
Don't bother with the expense of a cage if you only autocross the car. If you street drive the car also, definitely don't bother with a cage. Maybe a roll-bar if you really want *something* there.
As far as passing autocross tech with a cage... I venture to say that nobody ever teched my roll-bar in my miata at an autocross. Including at Nationals in Topeka. You can have style bars and pass (thinking those little hoop things people put in their miatas). For autocross, they are typically extra weight, and nobody generally wants that if they want to be compeditive.
Old Feb 22, 2005 | 02:36 PM
im really sorry...here is a corection. My car is not for streets at all. I ntend to race with it only. BTW when i say race, i mean something similar to Honda-Challenge H1 class. So it isnt just for "Auto-X" this is serious road racing
Old Feb 24, 2005 | 01:39 PM
ttt
Old Feb 24, 2005 | 02:07 PM
slammed_93_hatch's Avatar
Default Re: Auto-X Custom Welded Roll Cage (NinetyTwoHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NinetyTwoHB &raquo;</TD></TR><TR><TD CLASS="quote">ttt</TD></TR></TABLE>
why i thought mike already answersed your questions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeski38 &raquo;</TD></TR><TR><TD CLASS="quote">For a 92 civic, 1.5" x .095 is legal, but most of the time you have to ballast those cars to get them to meet min weight anyway, so I prefer to use 1.5" x .120 tubing for this application.
Building cages is not rocket science, but there are a few little tricks that make the difference between a good cage, and a cage that you will find yourself cutting out in a few months. So I would make sure you know what you are getting into. I would recommend spectating at a local SCCA or NASA race event to get some ideas before you start. Good luck!</TD></TR></TABLE>
the reason why your not getting any other answers is cause this is what most people do.
Old Feb 24, 2005 | 02:19 PM
so are most rollcages 1.5x.12 r around there???
Old Feb 25, 2005 | 03:52 AM
.RJ's Avatar
.RJ
Default Re: (NinetyTwoHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NinetyTwoHB &raquo;</TD></TR><TR><TD CLASS="quote">so are most rollcages 1.5x.12 r around there???</TD></TR></TABLE>
http://www.nasaproracing.com/r...e.pdf Section 4.9
http://www.nasaproracing.com/rules/ccr.pdf Section 15.6
Read the rulebook(s).
kings_blend
Welding / Fabrication
19
Oct 5, 2009 10:53 PM
del-sol-95
Jan 13, 2006 03:17 PM
tommyten
Feb 19, 2005 09:15 AM
baonest1
Jan 5, 2004 05:19 AM
Simon Tibbett
Oct 26, 2003 02:28 PM
