12 sec eg
Old Feb 21, 2005 | 07:46 PM
ilsimsli's Avatar
Default 12 sec eg
im about to put a gsr in my eg and i was wonderin what I should do to get the car into the 12s allmotor also it will be daily driven.
i had a b16 with spray and it was quick but then i turboed it and blew it up so i want something reliable so i figured i would go allmotor
thanks
Old Feb 21, 2005 | 08:05 PM
asubennett's Avatar
Default Re: 12 sec eg (ilsimsli)
lighten your car considerably, use some .025 over JDM ITR pistons, some Skunk2 stage two cams and appropriate valve train, a nice header (leave it open at the track)- hone your driving skills, use some 24' slicks. Knock down a 1.8 60ft and viola you ran a high twelve.
Search the archives in this forum and the drag racing forum- topic has been covered over and over and over and over and over and over and over and over and over and over and over and over and over and over and over
Old Feb 21, 2005 | 08:17 PM
Combustion Contraption's Avatar
You can break 12's on drag radials with a little higher compression (dont go over 11.5:1) , lumpy cams (bc 3+, jun 3), ITB's, decent header (smsp, an-r), and tuning. (Hondata, ems, uberdata, no VAFC only ****.)
Old Feb 21, 2005 | 08:42 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: (LsVtec92Hatch)
its all on your driving, cut the car, get some radials, stage 3 cams, and tranny work and your good to go
Old Feb 21, 2005 | 09:03 PM
asubennett's Avatar
Default Re: (Mattb16teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mattb16teg &raquo;</TD></TR><TR><TD CLASS="quote">its all on your driving, cut the car, get some radials, stage 3 cams, and tranny work and your good to go</TD></TR></TABLE>
what kind of tranny work?- leave the tranny alone
Stage three cams?- What are you gonna do to support those?
Radials?- Every car I know of has these unless you meant Drag Radials.
I guess he is "good to go" though
Old Feb 21, 2005 | 10:08 PM
midwesta's Avatar
i think he meant either get a tranny with LSD or put an LSD in, meh, i would just in all honosty get some sort of oem tranny with oem lsd cause they have the best gear ratios anyways, like itr.
and to support the stage3 cams, your gonna need an upgraded valvetrain/header/intake manifold/hondata(etc)/ignition(msd, if you want ignition, not really necessary)
Old Feb 21, 2005 | 10:41 PM
5STAR3's Avatar
Default Re: (techintegra)
there are countless ways to achieve what you have asked. search a little and come back with a more specific question; or hopefully learn enough to answer your own question.
good luck with the mota
Old Feb 21, 2005 | 11:22 PM
v-6 hatch's Avatar
Default Re: (envision2teg)
build an ls ... .screwe the v-tec guys haha ... what i would say is ctr pistons with a b-16 head with stage 3 cams and supporting vavle train. with a aebs manifodl and a bisheader/an-r/hytech/ and i got resprsent dtr b-unt( maybe they will hook me up) with a 65 m un tappered t/b with u should be close if not there and if that doesn't work .... build an ls
Old Feb 22, 2005 | 03:29 AM
Honda_Tengoku's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilsimsli &raquo;</TD></TR><TR><TD CLASS="quote">im about to put a gsr in my eg and i was wonderin what I should do to get the car into the 12s allmotor also it will be daily driven.
thanks</TD></TR></TABLE>
about 210ish WHP or so can get u in the 12's on a good set of falkien Azenis and some good driving in a hatch.
Old Feb 22, 2005 | 05:26 AM
v-6 hatch's Avatar
Default Re: 12 sec eg (Honda_Tengoku)
like envision2teg said theres many ways good luck take what u wnat from us and do it homie
Old Feb 22, 2005 | 06:50 AM
spooncivic1's Avatar
nitrous
Old Feb 22, 2005 | 07:22 AM
Phatch99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Tengoku &raquo;</TD></TR><TR><TD CLASS="quote">
about 210ish WHP or so can get u in the 12's on a good set of falkien Azenis and some good driving in a hatch. </TD></TR></TABLE>
agree
DSRxCandyh2bEG
Nov 29, 2012 12:22 PM
JDMCRX
Oct 26, 2007 02:01 PM
ranta18
10
Oct 4, 2006 07:39 PM
sway892
May 13, 2004 09:46 AM
The G2 Racer
11
Apr 7, 2004 04:03 PM
