Tips on Swapping cams installation?
Old Feb 21, 2005 | 04:49 PM
crxh22project's Avatar
Default Tips on Swapping cams installation?
im going to get CTR cams on my b16 do i have to loosen the tensioner to remove the belt? and stuff cause i dont want to remove the whole cover. cause on the CSpeed racing site is helpfull but it dont state that you have to remove belt tensioner.?
http://www.c-speedracing.com/h...m.php
Old Feb 21, 2005 | 05:04 PM
drdisco69's Avatar
Default Re: Tips on Swapping cams installation? (crxh22project)
To loosen the timing belt tensioner, you don't have to remove the covers, just take out the rubber plug on the cover, and that will give you access to the 14mm tensioner bolt.
You will have to loosen the tensioner to remove and install the belt. Loosen it half a turn or so, that should be enough. After you put the belt on, make sure you turn the motor over a few times to put tension on the belt. This will also allow you to check the timing and avoid problems.
Old Feb 21, 2005 | 07:49 PM
Default Re: Tips on Swapping cams installation? (drdisco69)
kewl thanks
dragonkx
Jul 13, 2011 01:41 AM
Mad-Mike
Jun 2, 2011 07:35 PM
vinuneuro
Sep 16, 2007 10:58 AM
43MA
Jan 7, 2005 06:43 PM
InTeGrA B18b1
Aug 20, 2003 07:57 AM
