What happened?(h22)
Old Feb 21, 2005 | 04:18 PM
blackdelslo's Avatar
Default What happened?(h22)
I was driving on the freeway, just cruising when the motor started to sound really bad like the timing was retarded ALOT. I pulled over and shut it off. Now it wont start, I check the plugs and 1-3 are very black. Im getting fuel, obviously air and I think it may be spark, about to check with the old screw driver trick.
Question is, can a distributor work perfect and then all of a sudden just crap out with no obvious signs? If not maybe its wiring. thanks
Old Feb 21, 2005 | 04:27 PM
mgags7's Avatar
how do you know youre getting fuel?
yeah i guess it could crap out all of a sudden, something in the coil could just go.....but unlikely.....
Old Feb 21, 2005 | 04:31 PM
Default Re: (mgags7)
update: Its NOT getting spark. I can hear the fuel pump prime when i turn the key once so it should be getting fuel. After i got it towed home I could take the key out and the lights on the cluster would stay on eg the brake light, oil light. I took out some fuses under the hood and then put them back and it doesnt do it anymore. Sounds really weird.
So do you think my dizzy is gone or that its wiring, im leaning more towards wiring, but where to start? I have a multimeter btw.
the distributor is a distributor king for the jdm h22 model, if that tells u anything.
Old Feb 21, 2005 | 04:37 PM
Hawkze_2.3's Avatar
Default Re: (delLudeVTEC)
Maybe the main relay. It's behind the dash to the left of the steering wheel...
Old Feb 21, 2005 | 05:30 PM
Default Re: (Hawkze_2.3)
How would I be able to tell if its the main relay?
Old Feb 21, 2005 | 05:42 PM
Hawkze_2.3's Avatar
Try a new one and see if that fixes it. Also run a search on main relay and you'll see what symptoms other people have had...some are similar to yours.
Old Feb 21, 2005 | 06:08 PM
LudeyKrus's Avatar
I woulda guessed a timing belt problem at first, but if you're SURE it's not getting spark at the plugs, check to see if it's getting spark going to the dizzy. If not, check for voltage going to the coil.
Old Feb 21, 2005 | 08:24 PM
Default Re: (LudeyKrus)
Its a jdm internal. I think its either the main relay or a fuse. Once i started pushing on fuses under the hood, the fuel pump started to prime again, before it wasnt. Also my autometer tach bounces all around, stays at like 10k and then jumps down and up randomly.
Old Feb 22, 2005 | 05:01 AM
Under_Pressure's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Its a jdm internal. I think its either the main relay or a fuse. Once i started pushing on fuses under the hood, the fuel pump started to prime again, before it wasnt. Also my autometer tach bounces all around, stays at like 10k and then jumps down and up randomly.</TD></TR></TABLE>
If you have fuel its not the main relay. As you stated above your tach bounces so Problem sloved, its your ignitor. $50 bucs new anywere online. while your at it clean the cap terminals and get new plugs "ngk".
Old Feb 22, 2005 | 10:22 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">I woulda guessed a timing belt problem at first, but if you're SURE it's not getting spark at the plugs, check to see if it's getting spark going to the dizzy. If not, check for voltage going to the coil.</TD></TR></TABLE>
that's what i thought it was too at first
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92h22alude &raquo;</TD></TR><TR><TD CLASS="quote">If you have fuel its not the main relay. As you stated above your tach bounces so Problem sloved, its your ignitor. $50 bucs new anywere online. while your at it clean the cap terminals and get new plugs "ngk".</TD></TR></TABLE>
you're right about the ignitor is bad, but where can i find an ignitor for 50 bucks at? you better try 170 bucks. find it for 50 bucks news, i bet everyone on hondatech will buy one or two just to keep for spares
Old Feb 23, 2005 | 04:07 AM
Default Re: (PrettyLude)
ok they raised the price but here you go happy B-day
http://www2.maximumautoparts.c...03270
Old Feb 23, 2005 | 06:19 AM
Default Re: (92h22alude)
Ok i followed the link and looked at the pic, i have no idea where that part goes...?
Do i get the one for the prelude or for my del sol? I have never seen that part. thanks
Old Feb 23, 2005 | 07:16 AM
PrettyLude's Avatar
that part is insider your distributor, they should be interchangeable
Old Feb 23, 2005 | 12:20 PM
If you got a h22 you need the prelude one.
bass man
Mar 14, 2013 08:16 PM
elite01
Honda Civic (2001 - 2005)
20
Nov 21, 2009 04:00 PM
just another ef
Aug 19, 2008 01:43 PM
civic702
14
Jan 15, 2005 05:11 PM
Slain
Aug 24, 2002 09:49 AM
