gsr pcv system
Old Feb 21, 2005 | 03:36 PM
danteisme's Avatar
Loved
Community Favorite
Default gsr pcv system
im goin to be hookin up my oil catch can this weekend hopefully, heres a question tho. all of the pages ive been to show you how to hook them up on b16's, or typer's and what not. you can clearly see from the pcv valve to its connection. on a gsr with a gsr intake manifold, where does the line go from teh pcv valve? i can see where thats at, but it looks like the line goes under the IM and dissappears? or better yet, anyone have any pics of this hooked up on thier gsr?
Old Feb 22, 2005 | 04:11 AM
JimBlake's Avatar
Default Re: gsr pcv system (danteisme)
Good luck, I can't really tell from the parts drawings either... It has to go to the manifold, so there must be a hose nipple down there somewhere, on the underside of the IM's plenum. Maybe you can see it from underneath??
Old Feb 22, 2005 | 06:32 AM
btatedash's Avatar
Default Re: gsr pcv system (JimBlake)
which part number are you talking about on that drawing?
Old Feb 22, 2005 | 06:54 AM
danteisme's Avatar
Loved
Community Favorite
Default Re: gsr pcv system (btatedash)
i think number 3 is the pcv valve, so im still not real sure where it goes
Old Feb 22, 2005 | 07:03 AM
seifer's Avatar
I thought #5 was the PCV valve? What is #5 then?
Old Feb 22, 2005 | 07:06 AM
4U2NV's Avatar
Default Re: gsr pcv system (fukushuu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danteisme &raquo;</TD></TR><TR><TD CLASS="quote">i think number 3 is the pcv valve, so im still not real sure where it goes</TD></TR></TABLE>
Number 7 is the PCV valve...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fukushuu &raquo;</TD></TR><TR><TD CLASS="quote">I thought #5 was the PCV valve? What is #5 then?</TD></TR></TABLE>
That's the rubber gromet that the PCV goes into...
Old Feb 22, 2005 | 07:09 AM
danteisme's Avatar
Loved
Community Favorite
Default Re: gsr pcv system (4U2NV)
doh thats what i meant, i duno why i said 3. do you know where it connects up to on the manifold?
Old Feb 22, 2005 | 07:14 AM
seifer's Avatar
I actually changed mine in my GSR yesturday and was wondering the same question..
My friend who's a mecanic told me it probably goes to some vacuuming system... Im not sure though, tell me if you get the answer.
Anyways I might jack up my car and find out myself tonight, Ill tell you if I do!
Old Feb 22, 2005 | 07:24 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">It has to go to the manifold...</TD></TR></TABLE>
That picture doesn't show where hose #13 goes, but IT HAS TO GO TO THE MANIFOLD. That's how a PCV system works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fukushuu &raquo;</TD></TR><TR><TD CLASS="quote">My friend who's a mecanic told me it probably goes to some vacuuming system...</TD></TR></TABLE>What system would that be? If you see a vacuum bottle wedged under the manifold, that's for the IAB system (secondary intake runners). You'll probably have to get that out of the way before you can see where that hose connects.
Old Feb 22, 2005 | 07:28 AM
seifer's Avatar
JimBlake,
Hum ok... I don't think I'll escalate the issue to that point but thanks for telling.
Actually, I didn't even know about that IAB system (secondary intake runners) .. what does that do?
Old Feb 22, 2005 | 07:29 AM
danteisme's Avatar
Loved
Community Favorite
yeah i know it goes to the manifold, im just not sure where. i tried following the line but it just dissapears from sight fromt he top of the car. next time i get a chance i'll see if i can follow it underneath the car.
Old Feb 22, 2005 | 07:42 AM
bert039's Avatar
got this from BSQ's website, he's got step by step directions on how to set one up and he's got a GSR
http://www.geocities.com/bretq....html
Old Feb 22, 2005 | 10:56 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fukushuu &raquo;</TD></TR><TR><TD CLASS="quote">Actually, I didn't even know about that IAB system... what does that do?</TD></TR></TABLE>Those long curvy intake runners are good for low-rpm torque. Then there's a 2nd set of runners, short, stubby, direct from the plenum to the ports. Those open up above about 5700 rpm. There's a vacuum reservoir under there to work the butterflys in the secondary runners. That makes it tough to see anything under there.
Old Feb 22, 2005 | 07:20 PM
stumpyf4's Avatar
Default Re: gsr pcv system (bert039)
If you're doing a standard catch can setup you need to splice in the catch can into hose #13... one side goes to the PCV valve (#7) and the other side goes to the intake manifold.
Pro-tip: If you use some clear reinforced PCV hose to splice in the hose going to the manifold from the catch can, it should remain relatively clear. Gives a good indication that the catch can is working.
Old Feb 23, 2005 | 08:00 AM
danteisme's Avatar
Loved
Community Favorite
Default Re: gsr pcv system (stumpyf4)
good tip. the can i bought comes with some clear hose so im goin to use that. in case anyone else was unsure of where its at, i was shown this pic. follow the hose to the IM from the red pcv vlave.
tylergrae
Apr 13, 2014 08:38 AM
shadydb7
Apr 8, 2009 03:37 PM
gsr dood
Mar 20, 2006 07:24 PM
