rocker shaft removal
Old Feb 21, 2005 | 03:26 PM
lilredhatch's Avatar
Default rocker shaft removal
anyone know what size allan wrench or hex key, whatever you want to call it, it takes to remove the threaded plug that holds the rocker shafts in a B18C1 head?
Old Feb 21, 2005 | 03:46 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: rocker shaft removal (lilredhatch)
I can't tell you exactly because mine are covered up...
It is between 8mm and 10mm I think..( I am thinking it was 10mm..}
If you have a ruler that reads in MM, Measure the distance between
two sides...
Old Feb 21, 2005 | 03:56 PM
Default Re: rocker shaft removal (88DXCRX)
thanks,
anyone know the exact size?
Old Feb 21, 2005 | 04:50 PM
88DXCRX's Avatar
#1 in this picture:
Old Feb 21, 2005 | 05:52 PM
Mike K's Avatar
10mm, i'm *almost* positive
Old Feb 21, 2005 | 06:21 PM
rjay8604's Avatar
Default Re: rocker shaft removal (Mike K)
It is for sure 10mm, i just had to buy one a day ago. Its 10mm i promise.
Old Feb 21, 2005 | 06:48 PM
88DXCRX's Avatar
Default Re: rocker shaft removal (rjay8604)
Anything that Gumby and Pokey says must be true...
Dekorum
11
Sep 1, 2013 06:45 AM
kornerk12
May 29, 2007 06:32 PM
-Gary-
28
Apr 4, 2006 06:15 AM
EliteCivicX
Suspension & Brakes
Feb 18, 2005 09:15 AM
B18EG6
Oct 19, 2002 05:19 PM
