Car sputtering at 3K and up.
Old Feb 21, 2005 | 01:21 PM
korndog's Avatar
Default Car sputtering at 3K and up.
I was driving my car normally today, not beating on it. I was in second gear when i took it up to 3k and my car started to sputter and barely accelerate. I put it back in first gear and took it up to 3k and the same thing happened. I then turned the car off and back on and drove it and it seemed fine. My car is a 95 jdm prelude h22a. Someone suggested changing the spark plugs since they have not been changed sinse i had the car. Has any one else had this problem? If so what was the fix.
Old Feb 21, 2005 | 01:25 PM
mgags7's Avatar
check out user "search" he had this same problem and fixed it with the click of a button
Old Feb 23, 2005 | 12:55 PM
korndog's Avatar
Default Re: Car sputtering at 3K and up. (korndog)
********UPDATE***********
Well i decided to start with the small problems. So i decided to change the spark plugs sinse it has not been done in a long while. So while facing the engine i took out the spark plug all the way to the right. Changed it then the next one, i got to the third one and pulled out the spark plug wire.
When i pull out the wire(the part down in the hole) it is covered in water aswell and the 4th one. Went to my mechanic, he said that sometimes moisture gets in. Said to crank it with the spark plugs out to get rid of ne water if there is some and replace the spark plugs and it shud be fine. So i litened to him and did this, tiny mist of water came out of the two left cylinders.
Replaced the plugs and started it up. It ran fine for the 5 minutes i took it for a drive, then i came home and parked it up. Decided to go out an hour later after 3 minutes of driving the sputtering started happening again. So i pull over and check it out. Pull out the spark plug wires(the part what goes into the hole) and drops of water are around the 2 left spark plug wires. So i limp it home and have it parked up not knowing what the problem is.
Some one suggested as a worst case scenereo that i have a cracked head
What are your thoughts on this, ne help is appreciated.
Old Feb 23, 2005 | 01:43 PM
korndog's Avatar
bump for help
Clairvoyant
11
Sep 10, 2006 09:36 PM
sickntired
Jul 20, 2006 03:31 PM
Downz
Apr 24, 2006 11:55 AM
RustyDX
Feb 25, 2003 07:13 PM
