Moisture affecting TPS?
Old Feb 21, 2005 | 11:29 AM
elevated's Avatar
Default Moisture affecting TPS?
So this past weekend I roll to California to pick up some interior parts for the DA. When I arrived at the hotel the car was purring at 800rpm. It rained all night and the next morning when I get on the road the car was idling high and was jumping up and down between 1000 and 2000rpm. After looking through everything, I came up with a guess that the TPS sensor has moisture in it. I'm back in Vegas now but it's raining over here also. I figure I was going to wait until it dries up. The TB is off a 90 intake manifold. The way it performs now, still idles between 1000 and 2000rpm, and when I let off the gas pedal, instead of a smooth decline it kind of cuts off then goes down. So there is sort of a jerk a second after I let off the gas. Mechanically everything seems correct. As far as electronically, I'm thinking moisture.
Old Feb 21, 2005 | 12:55 PM
miahmouse's Avatar
Default Re: Moisture affecting TPS? (elevated)
sounds more like IACV than TPS.
Old Feb 21, 2005 | 04:13 PM
8krdline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elevated &raquo;</TD></TR><TR><TD CLASS="quote">So there is sort of a jerk a second after I let off the gas.</TD></TR></TABLE>
i had this same problem when my tps wasnt adjusted to the right voltage so it could be the tps
mortificationrock
12
Jun 17, 2007 01:17 PM
Btothe3rdDegree
Oct 30, 2004 10:33 PM
igo4bmx
May 25, 2004 01:14 PM
UNDER PRESSURE
13
Jan 23, 2004 09:48 AM
quik1
Dec 19, 2003 03:32 PM
