CRX b16 Swap
Old Feb 21, 2005 | 10:14 AM
slwlasr's Avatar
Default CRX b16 Swap
We're currently swapping a b16 into a CRX HF with a d15b6 in it. When the motor arrived a bunch of the wiring had the connectors ripped/cut off. Does anyone know where to find some good info on wiring this thing up. We have the ecu to go with the engine.
Old Feb 21, 2005 | 11:21 AM
Katman's Avatar
Default Re: CRX b16 Swap (slwlasr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slwlasr &raquo;</TD></TR><TR><TD CLASS="quote">We're currently swapping a b16 into a CRX HF with a d15b6 in it. When the motor arrived a bunch of the wiring had the connectors ripped/cut off. Does anyone know where to find some good info on wiring this thing up. We have the ecu to go with the engine. </TD></TR></TABLE>
you can transfer some sensors from your HF engine over to the B16A engine and you can actually use your HF engine harness on the B16A being that its MPFi.
Old Feb 21, 2005 | 07:05 PM
slwlasr's Avatar
Default Re: CRX b16 Swap (Katman)
what sensors can be switched.. and what about the wiring for the vtec?
thanks in advance
Old Feb 21, 2005 | 07:12 PM
QUiKSR20's Avatar
You will have to wire a few sensors ( vtec etc ) but your best bet is to use the HF Harness and run the apropriate extra wires or even better convert to OBD1
OBD1 conversion will set you back around $400 or so but will run the car awesome! You need a conversion harness, an O2 sensor , a chipped ecu and an OBD1 or 2 dizzy good luck!
Old Feb 22, 2005 | 07:14 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slwlasr &raquo;</TD></TR><TR><TD CLASS="quote">what sensors can be switched.. and what about the wiring for the vtec?
thanks in advance</TD></TR></TABLE>
whichever sensors are missing and/or broken on your B16 engine. You have to manually wire VTEC in from the VT solenoid and pressure switch all the way to the ecu.
Old Feb 22, 2005 | 04:11 PM
Irish Integra's Avatar
Hasport probably make a subharness to add to your existing loom - easy fit, looks professional...and you get instructions!
border919
Sep 25, 2008 05:42 PM
kurruptedkustoms666
Oct 26, 2007 07:19 AM
EF_generation
Mar 13, 2006 06:44 AM
b16rexy
13
Jun 1, 2005 10:25 PM
