AEM EMS with a Supercharger
After thinking about different options, I think I am going to stick with my Vortech Supercharger. I want to upgrade some things without spending tons of money, so the AEM EMS came into mind. If I added it, what kind of increases will I see providing that I get a good tune? Also, what is the largest pulley/psi I could run without getting any internal work done?
if you can do 18psi with a turbo on the stock bottom, only mod is the headgasket.... then what make you think that you can't do it with a supercharger?? other then the fact that the max psi on a supercharger for our cars is like umm 15psi i think....
I consider a head gasket some internal mods since your are taking the engine apart to do. If your going that far you might as well not cheap out and just get lower compression pistons instead. This guy mentioned cheap mods. The higher the psi the more you risk. A good tune is essential.
Im not sure if sideways is running stock block. He has the most hp ive seen so far.
boostincoupe
Jun 19, 2003 12:35 PM
