t25bb and t28bb max wheel HP on h22a
Old Feb 21, 2005 | 08:34 AM
aj99si's Avatar
Default t25bb and t28bb max wheel HP on h22a
I know these turbos are a little small for a 2.2 but I want something that spools fast and can still achieve 300 whp. These turbos are only efficient to about 10 psi right. So what is the max power for these turbos. Motor is sleeved and has billet rods and wiseco pistons. compression ratio is about 9 to 1.
Old Feb 21, 2005 | 08:40 AM
PrettyLude's Avatar
you spend all that money to get ur motor built, that turbo is too small, waste of time and money
Old Feb 21, 2005 | 08:58 AM
aj99si's Avatar
Default Re: (PrettyLude)
t3/t4 my best bet then. What trim would be good for full boost by 3500.
Old Feb 21, 2005 | 12:18 PM
PrettyLude's Avatar
Default Re: (aj99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aj99si &raquo;</TD></TR><TR><TD CLASS="quote">t3/t4 my best bet then. What trim would be good for full boost by 3500.</TD></TR></TABLE>
57 or 60 trim will be fine
Old Feb 21, 2005 | 12:22 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">
57 or 60 trim will be fine</TD></TR></TABLE>
I get full boost by 4300 on a b18 with 57 trim.
That's .4 liters less then you so this should work for you
Old Feb 21, 2005 | 12:53 PM
Alstare's Avatar
Default Re: (adseguy)
I have a .60 trim and i get full boost by 3700rpm on my h22.
Old Feb 21, 2005 | 01:46 PM
speedworks's Avatar
Default Re: (Alstare)
way too small sir, 60 trim will be smooth like butter on a 2.2
Old Feb 21, 2005 | 02:41 PM
aj99si's Avatar
Default Re: (speedworks)
thanks for all the help
nuttybumpo
Sep 11, 2006 05:28 AM
oxSLEEPERxo
May 7, 2006 06:54 PM
blackpearlcivic
Jan 26, 2006 05:24 PM
idewson
Jan 10, 2006 12:58 PM
Mr.DC2TurBo
Feb 12, 2004 06:43 PM
