Shuddering Problem?
Old Feb 21, 2005 | 08:27 AM
accord95vtec's Avatar
HT White Ops
Default Shuddering Problem?
Recently in the the past week or so, I have notice that my car shakes while letting off the gas, yet does not happen all the time. As I speed up it's fine, but when i let off, it starts to shudder and make vibrations. But if I accelerate while this happens, it will stop. Could it be the transmission? Please help! Thanks
Old Feb 21, 2005 | 08:38 AM
SuperSlow's Avatar
Default Re: Shuddering Problem? (accord95vtec)
Is your EGR clogged?
Check your plugs.
When is the last time you changed your Tranny Fluid?
Old Feb 22, 2005 | 07:20 AM
HT White Ops
Thanks, i'll check those problems out...anything else i should check?
Old Feb 22, 2005 | 02:45 PM
98blkaccord's Avatar
Default Re: (accord95vtec)
yea make sure that your intake is bolted down and not just attached to your throttle body... happened to me until i bolted the sucker down...might also want to check the PCV valve (did that the same time i bolted down the intake) and voila no shake shakes
Old Feb 23, 2005 | 07:33 AM
HT White Ops
Which of these problems could cause poor gas mileage, any idea? Because lately i've been getting only 300-315 miles on a tank, and I doubt it's a coincidence... Any suggestion?
Thanks for the input so far
Old Feb 23, 2005 | 05:02 PM
SuperSlow's Avatar
Does your winter gas have additives? If so, then that is part of it. Otherwise people often forget that in the winter they warm up their cars longer, and cold starts burn lots of fuel as well..
Old Feb 23, 2005 | 08:11 PM
HT White Ops
There are no additives, jus regular gas. And while it's cold outside, I always let my car warm up before driving.
The problem is getting worse, so tomorrow my dad will look at it, since i've been at school and work.
Thanks again.
Old Feb 24, 2005 | 05:57 PM
HT White Ops
Thanks superslow! It ran fine after unplugging the EGR, which was clogged. But only after we replaced the plugs, wires, distributor cap, and dist. rotor. Thanks!
Old Feb 24, 2005 | 06:52 PM
SuperSlow's Avatar
Anytime.
Old Feb 25, 2005 | 04:11 AM
boiwitwhitehond's Avatar
Default Re: (SuperSlow)
could yall please post pics of the egr valve..b/c my car seems to be doing the same thing..kinda..96 accord lx thank you very much
mike703
Feb 4, 2012 08:11 PM
civic_jones
Aug 26, 2008 08:48 PM
Si Arn
Aug 14, 2008 11:53 AM
atm3535
Jan 30, 2006 01:32 PM
TomM
Honda S2000
Jul 31, 2001 06:56 AM
