Pic's of my car after Tan to black interior swap
The most pain the *** part was puting in the new sun roof sun shade. You have to bring down the whoel sun roof assembly to change it. I started at 1pm adn din't finish till 8pm. Take into account that i had to clean all the new pices and i vacumed and wiped down the whole inside of tha car before i put the new pieces back in . The seat belts weren't that hard to change.
did you use some sort of spray for your carpet? or did you buy new carpet? the integra i'm picking up has ugly tan too, and i want to change it to all black interior. is that a black dashboard too? or just painted?
My 5 lug came of a JDM itr so im running the 36mm hubs. The rear is a bolt on bu tthe front requieres machineing of the hubs to fit into the DA bearings. If done correctly you should not have a problem but it is not a cheap mod. The machening is not cheap ither.
thats what ive heard. could i use the usdm type-r suspension and avoid the machining? i think they are still 36mm hubs on usdm also....
car looks bangin with the recaros, jdm one piece headlights, and the gunmetal itr 5 lug! Now you need a FRESH paint job and your car would be prett much off the hook
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ »</TD></TR><TR><TD CLASS="quote">car looks bangin with the recaros, jdm one piece headlights, and the gunmetal itr 5 lug! Now you need a FRESH paint job and your car would be prett much off the hook
</TD></TR></TABLE>indeed. first the inside, now the outside!
to the max.
