Mugen Air Intake Fit RHD with AC?
Old Feb 20, 2005 | 10:50 PM
RhdRicheeee's Avatar
Default Mugen Air Intake Fit SIR-G RHD with AC?
I have a 94 SIR-G RHD integra with AC
will this fit?
It says the vehicle must have no AC but since my car is RHD will this fit since the AC lines are on the other side?
Intake System Integra 1997-2001 Type R. No AC. Fiberglass
Old Feb 21, 2005 | 12:39 AM
Takumi Fujiwara's Avatar
Default Re: Mugen Air Intake Fit SIR-G RHD with AC? (e5et)
I can't find the thread where a guy got this to fit on his USDM integra WITH A/C. He just bent the A/C lines out of the way of the intake. If you don't have 2 black lines under your stock intake box, you'll have no problem installing this mugen intake. Good Luck.
Old Feb 21, 2005 | 04:53 PM
Default Re: Mugen Air Intake Fit SIR-G RHD with AC? (Takumi Fujiwara)
so it wil fit??
Old Feb 21, 2005 | 05:17 PM
JDMisGOOD's Avatar
it should
Old Feb 21, 2005 | 05:21 PM
JamaicanDM's Avatar
yea it should fit if u bend the ac lines
Old Feb 21, 2005 | 07:29 PM
Default Re: Mugen Air Intake Fit SIR-G RHD with AC? (JamaicanDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JamaicanDM &raquo;</TD></TR><TR><TD CLASS="quote">yea it should fit if u bend the ac lines</TD></TR></TABLE>
I still will have to bend the lines even though my cars RHD?
Old Feb 21, 2005 | 07:57 PM
look under your stock intake box and see if you have those 2 A/C lines. I have no idea what's particularly different about the RHD integra engine bay besides the throttle cable routing... so the best way is to see if anything under you stock intake box would restrict the mugen intake from fitting. It takes like 5 minutes to remove the box... either that, or see if you can see if the A/C are actually routed the same way as in USDM integras.
Old Feb 26, 2005 | 10:42 PM
iheartintegras
Aug 20, 2009 10:58 AM
supracrx
Oct 25, 2006 12:02 AM
CRVRX
Jan 27, 2005 01:03 PM
guyuenvy
Feb 28, 2002 06:17 PM
