Port n Polish. Yes or No?
Old Feb 20, 2005 | 09:24 PM
caranjo's Avatar
Default Port n Polish. Yes or No?
I've been debating PnP for a while now and just can't make up my mind. Is it worth it? I'm looking for more low to mid end power - will skimming followed by PnP justify the outlay for achieving power in this range? If you have done it on the B16A head and have the standard bolt ons + ctr cams (tuned) let me know.
Old Feb 21, 2005 | 03:52 AM
caranjo's Avatar
Default Re: Port n Polish. Yes or No? (caranjo)
Old Feb 21, 2005 | 08:58 AM
Mr Black's Avatar
Looks like a street porting job like Alaniz can offer some decent bang for the buck:
https://honda-tech.com/zerothread?id=1149781
If you are careful and knowledgeable, bottom end and midrange should usually improve from a P&P. Getting a nicer short-side radius, removing the factory casting junk and a 3-angle valve job can only help your power everywhere in the rev range. It's only when you start making ports too big that the low-end starts to suffer.
Quite honestly, if you really want low-end though maybe you should be doing an LS block swap.
sivikvtec
48
Feb 8, 2007 10:30 AM
CiPs33
Dec 1, 2005 03:37 AM
HondaFanatic708
33
Jul 28, 2005 06:24 AM
DragSource
Mar 2, 2005 07:42 AM
caranjo
Feb 11, 2005 12:17 PM
