Air to fuel ratio...
Old Feb 20, 2005 | 07:39 PM
civicgsr19's Avatar
Default Air to fuel ratio...
Looking for some input into AFR. I have a plx m-300 wideband and a vafc that i use for basic tuning, just to get my car to run alittle better on the street. well whats a safe AFR to run around on, is the stoich 14.7 the ideal at all crusing times? Or can i run slightly leaner to get some more mpg? as of right now i have it around 14.7-15.3 at cruising and around 12.8-13.5 at wot. Thanks for any help....
Old Feb 20, 2005 | 07:55 PM
Tbone's Avatar
Default Re: Air to fuel ratio... (civicgsr19)
You can run 15.5 fine under light load.. When its real hott and under load is where you need to be worried..
Old Feb 20, 2005 | 08:14 PM
civicgsr19's Avatar
Default Re: Air to fuel ratio... (Tbone)
thanks tbone. Thank god it dosen't get real hot here in oklahoma, the heat is the only thing I don't miss from arizona. That and emissions
Old Feb 22, 2005 | 08:44 PM
civicgsr19's Avatar
Bump fo moe info...
Old Feb 22, 2005 | 09:44 PM
athoughts's Avatar
bump
Old Feb 22, 2005 | 09:52 PM
Combustion Contraption's Avatar
as t-bone stated 15.5 is fine under light load during normal weather conditions, stoich is fine for part throttle, VTEC will like to run a little richer than 14.7, and as the RPM increases so should the ratio of fuel to air. Part of this is to keep combustion chamber temps under control.
Old Feb 23, 2005 | 01:22 AM
Rocket's Avatar
Default Re: (LsVtec92Hatch)
14.7 is good for crusing and idle for OBDI ecu equipped cars. Low or higher in closed loop operation will kick in long term fuel enrichment or "leanment"
spriggan
Sep 25, 2006 09:21 PM
irocdaparty85
Oct 28, 2005 10:36 AM
litterbox
Feb 9, 2005 12:43 PM
Benjithx
Jan 13, 2005 10:08 AM
