11.3-1 compression, what cams have stock like idle but good vtec power?
Old Feb 20, 2005 | 07:39 PM
smalltownsleeper's Avatar
Default 11.3-1 compression, what cams have stock like idle but good vtec power?
just like the topic says. I'm just running a stock bore gsr with jdm itr pistons and other sutff. I was looking at the BC 4 cams but didn't like how it idled. I'm looking for a pretty aggressive cam that isn't too lopey at idle. I heard that the s2s2/ Blox B are pretty good.. Any other suggestions?
Old Feb 20, 2005 | 07:49 PM
Tbone's Avatar
Default Re: 11.3-1 compression, what cams have stock like idle but good vtec power? (smalltownsleeper)
Rocket m22's . /these have good vtec power with reasonably sized primaries.. Plus if you buy the Rm cam package it comes with springs/retainers and a custom burnt chip for you to use a basemap for your tunning.. all you would need is a socketed ecu to run the chip and you will be able to open and modify the program as needed if you have your own burner.
Terrible One's Avatar
rocket motorsports m22
Old Feb 20, 2005 | 09:57 PM
THEUSED's Avatar
Im curious as to what RPM M22s stop making power at?
Old Feb 20, 2005 | 10:57 PM
Tbone's Avatar
Default Re: (THEUSED)
Theres alot of things besides the cams that determine where it stops making power.. So comparing dynographs isnt the most accurate from motor to motor.. I know by changing from a ported skunk to a Jg sheetmetal it moved my peak power almost a 1000 rpm higher, my hp didnt change just the points where it was making power..(the graph below isnt for this however)
All that said here's the m22x vs a skunk pro-1 on a itb car"(not mine)
Modified by Tbone at 6:04 AM 2/21/2005
Old Feb 21, 2005 | 12:48 AM
sheepey's Avatar
what compression u at again Tom?
Old Feb 21, 2005 | 12:59 AM
THEUSED's Avatar
Hes at like 13.6:1
Old Feb 21, 2005 | 02:02 AM
Tbone's Avatar
Default Re: (sheepeg3)
GUY"S thats not my motor. Thats 11.1 -11.5 I Beleive
Old Feb 21, 2005 | 05:58 AM
No_Fear's Avatar
Peak Perfomance cams have stock idle.
With same cr 11.3:1 and toda spec C ,will it work fine ? idle problems?
thanks
Old Feb 21, 2005 | 10:19 AM
DonF's Avatar
Default Re: 11.3-1 compression, what cams have stock like idle but good vtec power? (No_Fear)
Skunk2 stg. 3 have a very calm idle and large vetec lobes.
crookson speed
Mar 21, 2017 11:10 AM
91tegrsjg
Jan 2, 2010 06:03 PM
bombDOTcom
17
Sep 18, 2006 11:19 AM
itr1244
Apr 3, 2005 07:37 PM
JinMTVT
12
Dec 21, 2004 08:31 PM
