electric water pump & fan with relay????
Old Feb 20, 2005 | 06:32 PM
h22 civic's Avatar
Default electric water pump & fan with relay????
can i run a electric water pump and fan off of one 30 amp relay i want them to be on at the same time also what size fuse shold be used if i can
Old Feb 21, 2005 | 05:19 PM
h22 civic's Avatar
Default Re: electric water pump & fan with relay???? (h22 civic)
Old Feb 22, 2005 | 05:05 AM
JimBlake's Avatar
Don't you want the waterpump running ALL THE TIME? Not just when the fan comes on...
Old Feb 22, 2005 | 12:08 PM
h22 civic's Avatar
Default Re: electric water pump & fan with relay???? (JimBlake)
does this look rite?
well im planning to put a thermoswitch in line with both the fan and water pump so they will go on at a certain tempbut also want to be able to turn them on manually whenever i want
Old Feb 22, 2005 | 12:45 PM
JimBlake's Avatar
I still don't get it. Why don't you want the pump to run full-time, as long as the engine's running? Is this the kind of pump where you remove your belt-driven waterpump? If so, you gotta remember that there should always be flow going thru the block & head. Thermostat shuts off flow ONLY to the radiator.
Old Feb 22, 2005 | 01:22 PM
h22 civic's Avatar
well this is an externall electric water pump i dio not have a oem water pump in my car i drilled holes around my thermostat so some water still flows through motor but if i keep the pump on costantly my motor will never warm up thats why i put a thermo switch when im normall driving it will kick on at a certain temp but when im inbetween rounds of racing i want to be able to manually turn the pump and fan on to cool down fast
Old Feb 22, 2005 | 01:46 PM
NJIN BUILDR's Avatar
I wouldn't use a thermostat at all.Just use a restictor.Some people take the thermostat and gut it out.Make sure you have the punp on during a run.You will get localised hot areas and start to detonate faster than the relay can react. http://www.moroso.com/catalog/...29018
Glenn
Old Feb 22, 2005 | 02:28 PM
h22 civic's Avatar
Default Re: electric water pump & fan with relay???? (NJIN BUILDR)
i was thinking bout the restrictors
tony1
May 30, 2013 09:15 PM
ranta18
Nov 12, 2009 08:04 AM
brewerdude
Jan 8, 2006 06:31 PM
full Circling
Jun 30, 2005 02:37 AM
BB6-213
Mar 20, 2005 02:37 PM
