p30s into a lsvtec
Old Feb 20, 2005 | 05:31 PM
JIDUM_Undercover's Avatar
Default p30s into a lsvtec
What kind of modifacations do i need to put the p30 b16 pistons into a b18a lsvtec setup??? I just got a b16 shortblock so im going to see what i need to put them into it. TIA.
Old Feb 20, 2005 | 05:41 PM
chameleon's Avatar
Default Re: p30s into a lsvtec (JIDUM_Undercover)
i would expect this to have been covered already, but all you need is to switch em over to the LS rods, need a machine shop to this since they are pressed on, and oh you need a hone on your LS block and get new oem bore piston rings.. im not gonna go on how to put it all together just have a proffesional do your work.
Old Feb 20, 2005 | 07:56 PM
Ive built plenty of motors before, i was just curious, would this be better then the ls pistons and what rings should i order b16?
Old Feb 20, 2005 | 08:23 PM
bump?@?@?@?
Old Feb 20, 2005 | 10:26 PM
rextec's Avatar
just use the rings from the pistons you are using (b16)
Old Feb 20, 2005 | 10:46 PM
shorto85's Avatar
http://www.bojangs.com/calculator/
^ nice tool to figure out the CR you will get with that setup
Old Feb 20, 2005 | 10:54 PM
thevanitygroup's Avatar
Default Re: (shorto85)
To answer your questions:
1. P30 pistons are the most "IDEAL" OEM piston for any b-series engine. Light, flatter, valve reliefs, fit on rods easily, yield C/R that is tunable and come oversized (which I suggest you use). THEY ARE FAR SUPERIOR TO LS PISTONS.
2. Use the OEM piston rings that match your piston and NOT application. Some people use Hastings, I always prefer OEM.
Good luck.
Old Feb 21, 2005 | 04:57 AM
hell yeah i appreciate all the help guys, I went around yesterday and tried to find someone to press pistons onto rods. No one in richmond will does anyone know where i can go to get the p30s put on ls rods???
Old Feb 21, 2005 | 06:05 AM
i could go to the beach to, to get them pressed so any shops from chesterfield to va beach let me know.
Old Feb 21, 2005 | 10:36 AM
Old Feb 21, 2005 | 10:38 AM
ttt?
evilclown312
Jul 12, 2012 08:13 PM
b18ek670
Apr 12, 2006 10:59 PM
mkinpwrat12g's
Sep 1, 2005 08:25 PM
91civicDXdude
Jul 16, 2003 02:20 PM
gocivicgo
Jul 16, 2003 12:09 PM
