Rear power window does not work!!! PLEASE HELP!!!!
hey guys,
i got a 91 accord 4dr and today while i was lowering the rear right window, it stopped half way and stop functioning. the main window switch and the switch on that door do not function at all as well. i checked the fuses and all the power window fuses are ok. i removed the window switch from the rear left door and tried it on the non fuctioning door and it still does not roll up. i also noticed that the lower light on the door do not light up when the door is open. the lights on the other doors light up when the door is open. is there maybe some reason there is no power going to that door? car is completely stock. please someone help!!! its raining here and i have this stupid trash bag with duck tape on it.
TIA
TIA
happened to me, cept left rear. we took the door apart and manually rolled up the window, then i put duct tape over the switches, but you can disconnect them if you want. im not positive but i believe its the window motor
Check the wiring to the master switch or the switch itself. I fixed a similar problem on my 91 by opening up the master switch and scraping clean the metal contacts inside it. Either way bust off the door panel to the window you need to put up and apply power to the motor to get the window up for now. This way you'll find out if the motor is burnt out or not.
before you condemn anything chk to see if you are getting power at motor,,if not you got a wiring or fuse problem putting a new motor is a waste of money if you get power chk for a good ground as well you need both to make motor work if you have power and ground then you need a reg/motor asembly
dustdevil06
Honda Civic (2006 - 2015)
May 4, 2013 08:16 AM
chris4x4
13
May 8, 2011 10:39 AM
killaxkev92288
Honda Civic (2001 - 2005)
Apr 22, 2010 09:14 AM
