205/55/15???
Old Feb 20, 2005 | 04:16 PM
civic702's Avatar
Default 205/55/15???
i'm looking in purchasing some new tires. i mainly just drive to school and back. was wondering if i should step up to a 55 from a 50 series for comfort wise. have no p.s. so i feel everything compared to the other vehicle which as p.s. any inputs???
Old Feb 20, 2005 | 06:42 PM
Moogen Powah's Avatar
Default Re: 205/55/15??? (civic702)
If you want to move to a 55 series tire, the correct size would be 195/55/15.
Old Feb 20, 2005 | 08:03 PM
civic702's Avatar
Default Re: 205/55/15??? (Moogen Powah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moogen Powah &raquo;</TD></TR><TR><TD CLASS="quote">If you want to move to a 55 series tire, the correct size would be 195/55/15.</TD></TR></TABLE>
would u mind explaining why? cause isnt 205 wider.
Old Feb 20, 2005 | 08:47 PM
Beetle's Avatar
the 195/55/15 would then be the same height as the 205/50/15
Old Feb 20, 2005 | 09:39 PM
LoooseGSR's Avatar
Default Re: 205/55/15??? (Beetle)
When I bought my Integra, it had 205/55/15's on it...they rubbed...got rid of them as soon as I could.
Old Feb 21, 2005 | 12:51 PM
SumKrazeeDoode's Avatar
Default Re: 205/55/15??? (PSUCRX)
I just bought 225/45/17's. Try that for rubbing =P
Does anyone know how high I gotta revv my integra to get it to launch? With stock donuts I used to launch at 3000 RPM's at a creeping speed. I tried to do that with these today and then my car started bouncing like CRAZY! I then tried it again at a 8 - 10 mph roll, floored it and the same thing happened!
Can anyone tell me what I need to revv it to with a pretty much stock integra on stock springs, at a complete stop?
Old Feb 21, 2005 | 01:34 PM
LoooseGSR's Avatar
Default Re: 205/55/15??? (SumKrazeeDoode)
Seriously you're kidding right? If you're getting wheel hop, that's associated with the suspension, nothing you can do unless you want to change it. You're wheel hop is because the suspension won't keep the wheel pressed on the ground.
Old Feb 21, 2005 | 01:39 PM
I figured as much, but if I drop these I pretty sure major scrappage will happen. But for the mean time, any suggestions on springs that will keep these pressed on the ground but give oem quality ride? I heard Tein is pretty good, what else is there? COILOVERS ARE OUT OF THE QUESTION.
mingbling96
Mar 21, 2005 08:49 PM
v0lcom27
10
Feb 15, 2005 09:50 AM
integraboi1010
Jun 11, 2004 10:33 AM
infantry
11
Apr 28, 2004 04:21 AM
kinvid22
Mar 30, 2004 12:06 AM
