speedo problem with v-tec
Old Feb 20, 2005 | 03:16 PM
j_max420's Avatar
Default speedo problem with v-tec
i have a 91 hatch with a b16, my speedo cable broke, ever since my speedo cable broke my vtec doesnt work, is there any relation
Old Feb 20, 2005 | 03:29 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: speedo problem with v-tec (j_max420)
Yes,
VTEC requires temp, oil, and speed greater than 30 mph.
Old Feb 20, 2005 | 03:34 PM
j_max420's Avatar
Default Re: speedo problem with v-tec (mar778c)
so when my speedo cable comes in my vtec will work
Old Feb 20, 2005 | 06:03 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_max420 &raquo;</TD></TR><TR><TD CLASS="quote">so when my speedo cable comes in my vtec will work</TD></TR></TABLE>
Yes. Your check engine light should be on and throwing the VSS code.
Old Feb 20, 2005 | 06:04 PM
EP3_05's Avatar
Default Re: speedo problem with v-tec (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes. Your check engine light should be on and throwing the VSS code. </TD></TR></TABLE>
The CEL "should' be on. However, I had a code 17 and my CEL wasn't on so who knows.
Old Feb 22, 2005 | 06:26 PM
efrex's Avatar
Default Re: speedo problem with v-tec (91civic)
hi guys..im new here..i have a 91 crx si with a b16..my speedo doesnt work..so does it mean vtec is not workin?
Old Feb 22, 2005 | 06:46 PM
EP3_05's Avatar
Default Re: speedo problem with v-tec (efrex)
Yes if your ecu is showing a code 17 then VTEC is not working.
VTEC needs three inputs to work.
Coolant temp
Oil pressure
Speed above (i think) 30mph
Old Feb 22, 2005 | 08:47 PM
efrex's Avatar
thanks for the info..i have a couple more questions..it doesnt show check engine light, i havent checked my ecu.i will check it 2morrow what if its not throwin a code?should i still worry? and some1 told me this problem is only on 0bd-1 cars..mine is obd-0..is this true or is this problem for all b16s? thank u again,i appreciate it
Old Feb 22, 2005 | 09:51 PM
thatbluecrx's Avatar
i have a 1st gen b16 and when my speedo snaped i got a check engine light and no vtec, fixed the cable and everything is fine
Old Feb 23, 2005 | 09:01 AM
efrex's Avatar
Default Re: speedo problem with v-tec (thatbluecrx)
well i checked my ecu today..its not throwin n e code and i have no check engine light. and my speedo still not working..even if im not gettin a code,do i still have no vtec? thanks guys,i appreciate it
Old Feb 23, 2005 | 09:11 AM
manson's Avatar
if you can't hear a change in the exhaust note after 5200rpms than no you vtec is not working.
if the speedo doesn't work it shouldn't work.
91EF_Si
Jul 4, 2007 09:58 PM
DA_JDM
14
May 30, 2007 08:40 AM
crxdxsir
11
Nov 14, 2006 08:39 PM
ITR.#1446
Oct 18, 2005 06:49 PM
fastcat1
Dec 31, 2002 01:13 PM
