Part names and numbers..?
I need the names and part #'s (if that's possible) of the 2 pulley's circled in red. I suspect one is the timing belt pulley, but what about the other? Also, are there any sites I can order these from?
the upper one is the water pump. part # depends on if you want the ls, or if youd like to upgrade to the gsr.
you can find it here... http://www.acuraautomotiveparts.org
i dont know what else to call the other one other than the crankshaft gear. if you ask for a crank pulley, you might get the pulley for the alt, ac and ps belts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 »</TD></TR><TR><TD CLASS="quote">the upper one is the water pump. part # depends on if you want the ls, or if youd like to upgrade to the gsr.
i dont know what else to call the other one other than the crankshaft gear. if you ask for a crank pulley, you might get the pulley for the alt, ac and ps belts.</TD></TR></TABLE>
couldnt have said it any betterrr!
Assuming this is for the 92 LS in your sig ... #12
http://www.acuraparts247.com/s...ch=no
DB1_559
May 19, 2006 10:28 PM
