thermostat install
Old Feb 20, 2005 | 01:41 PM
darkd1gt's Avatar
Default thermostat install
i have a jdm h22a in my 95 lude and my thermostat went out this weekend. So when i went to put a new one in i got a 95 vtec one even though it was smaller i reused the gasket, then put it in but it kept leakin. I eventually had to use some gasket paper and silicon gasket maker on it to get it to stop from leaking. Has anybody else had this problem on install.
Old Feb 20, 2005 | 08:37 PM
five-0's Avatar
Default Re: thermostat install (mattspivey)
I saw this thread hours ago and saw that noone has replied..... so I just wanted to say, No, this hasn't happened to me. Goodluck.
Old Feb 20, 2005 | 08:45 PM
Nikoli's Avatar
Default Re: thermostat install (five-0)
well first off the reason why its leakin is bc you used the same gasket. did you get the thermo from honda? if not thats why you didnt get a new gasket with it. i just changed mine a couple months agoe it hasnt leaked a drop. if were you i would get that gasket from honda
Old Feb 21, 2005 | 03:04 AM
aaaabbbb's Avatar
Do not purchase anything from me. -HT Staff
i would get the thermostat and gasket from honda
Old Feb 21, 2005 | 03:09 AM
justanotherlude's Avatar
the jdm thermostat is different then the usdm thermostat.
Old Feb 21, 2005 | 04:14 AM
littledan's Avatar
the service manual says to use gasket maker on the the thermostat housing when you reinstall it. i used an aftermarket thermo and reused my stock gasket and it's fine no leaks
Old Feb 21, 2005 | 04:37 AM
kulrevon's Avatar
I had a problem with the size of the thermo when I changed out mine. I had to go around and find the right size I had to try a couple different shops. Go to a shop you can look in the book. and just look at all the different thermosats for h series motors. find the one thats the right size and im sure it has a matching gasket number. mine never leaked after i put it together.
Old Feb 21, 2005 | 04:50 PM
darkd1gt's Avatar
Default Re: thermostat install (kulrevon)
thanks 4 the replys. i got it sealed up. That is interesting about sayin to use a gasketmaker. Later that night i out ran an evo from a roll.
Old Feb 21, 2005 | 05:05 PM
superturboprelude's Avatar
Default Re: (justanotherlude)
dont spoon makes a thermostat that fits the jdm h22a for 4th gen?
Old Feb 21, 2005 | 06:10 PM
LudeyKrus's Avatar
Default Re: (superjunprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superjunprelude &raquo;</TD></TR><TR><TD CLASS="quote">dont spoon makes a thermostat that fits the jdm h22a for 4th gen?</TD></TR></TABLE>
I've only heard of the Mugen thermostats for the H22's, but it was the gasket that the thread starter was askin about.
Old Feb 21, 2005 | 11:16 PM
jdmcivicferio's Avatar
The JDM and USDM thermostats are the exact same....
get it from honda, after market parts never fit...
Old Feb 22, 2005 | 01:09 AM
enigma94's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">
I've only heard of the Mugen thermostats for the H22's, but it was the gasket that the thread starter was askin about.</TD></TR></TABLE>
I have the mugen thermostat in my h22, comes with a new seal and fit PERFECT, car also runs a lot cooler .
Old Apr 20, 2005 | 04:30 PM
cpforyou's Avatar
Default Re: (jdmcivicferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">The JDM and USDM thermostats are the exact same....
get it from honda, after market parts never fit...</TD></TR></TABLE>
You sure? I went to the dealer, and they showed me a smaller one.
I have a JDM H22A.
I went to Autozone & Kragen, and they showed me the same small sized thermostat. I went though the books at Autozone, and there was one that was a different part number, so I asked if they had it. They did, and it was the same size, but it was a Prestone Thermostat. Not sure if I should trust it or not.
Old Apr 20, 2005 | 04:47 PM
mgags7's Avatar
the jdm and us are the exact same thermo....no dispute because i have put 3 us new thermos in jdm h22s now....
buy honda parts for your ******* car, dont cheap out, you pay for it....
and NEVER reuse gaskets on coolant stuff....they leak like a loose ******* after one use.....
^^eww....
Old Apr 21, 2005 | 08:54 AM
cpforyou's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">the jdm and us are the exact same thermo....no dispute because i have put 3 us new thermos in jdm h22s now....
^^eww....</TD></TR></TABLE>
I did go to Honda also. It was SMALLER! I went to Honda
Agggh.... maybe i'll try a different Honda today.
Old Apr 22, 2005 | 04:48 PM
cpforyou's Avatar
Default Re: (cpforyou)
Finally! I found it!
https://honda-tech.com/zerothread?id=1222323
CORRECT PART NUMBER 191301-P13-305
This is for a JDM H22A
Old Apr 22, 2005 | 09:23 PM
mgags7's Avatar
damned corrupted honda dealers....i never had a problem getting the right parts for my jdm h22a....
i always use 94 prelude vtec as the car on majestic, and everything is the right size that way....i only did this b/c my engine is a 94...but it seems to be working out....
journeyquest
Sep 3, 2010 12:39 AM
alotawatts
Sep 2, 2007 03:00 PM
B16Civic93
Feb 17, 2005 10:31 PM
91HATCH
19
Jun 9, 2004 10:25 AM
