what is the problem so i can fixed it
Old Feb 20, 2005 | 01:20 PM
hbkid92591's Avatar
Default what is the problem so i can fixed it
i Have CRX with a D16Z6, the car stared heating really bad. I know it has a bad radiator, the car has overheated alot of times before, but this one time it over heated really bad and the motor starts shaking real bad, Theres also water on one of the the things were the spark plug goes. Another thing is that i think i might of put the spark plug wires in the wrong place so i think it misfired. If you people can tell me what the hell i did to **** up my car please i will really appretiate the help.
Old Feb 20, 2005 | 01:28 PM
d16efsedan's Avatar
Default Re: what is the problem so i can fixed it (hbkid92591)
if i was you i would pull the head and check that out probably cracked or warped it.....
Old Feb 20, 2005 | 02:04 PM
kulangot's Avatar
Default Re: what is the problem so i can fixed it (d16efhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16efhatch &raquo;</TD></TR><TR><TD CLASS="quote">if i was you i would pull the head and check that out probably cracked or warped it.....
or head gasket....
Old Feb 20, 2005 | 04:01 PM
d16efsedan's Avatar
Default Re: what is the problem so i can fixed it (sirq2u)
yeah,thanks for that forgot about that but sounds like he overheated her pretty bad never a good thing for the head.............but good catch none the less
Old Feb 20, 2005 | 04:06 PM
520_Motorsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirq2u &raquo;</TD></TR><TR><TD CLASS="quote">
or head gasket....</TD></TR></TABLE>
bet money on the head gasket. the bad shake was due to the lack of coolant in the head i would check it right away!
Old Feb 20, 2005 | 04:30 PM
doublethink's Avatar
hbkid92591,
your saying it overheated many times like thats no big deal. thats how things get warped.
fix your coolant system, and do the headgasket and pray it holds when you put it all back together, and check the level everyday if you have to.
Old Feb 20, 2005 | 05:59 PM
hbkid92591's Avatar
yeah i was careless with the car i feel bad about it. My friend the guy who swapped the motor on the car said i might have a warped head i have not yet check the head yet but i will see. hey guys what else should i check for other then structural damage
hondaboy9506
Dec 28, 2010 11:32 AM
Hecdosage
Oct 28, 2005 04:48 AM
Dr Pooface
May 14, 2005 10:03 AM
Slomies
Apr 22, 2005 09:08 AM
2dark2bslow
Jun 14, 2003 08:08 PM
