HELP!!!!, with hcp
Old Jan 18, 2002 | 06:18 PM
iwhichisme's Avatar
Default HELP!!!!, with hcp
I know ive asked this question before, but im having a hard time understanding some of your responses. The question is , how to get the front mount to work on the hcp kit. Someone has mentioned to me that i would have to slot the ears in order for it to work, but i dont fully understand what that means. If anyone has any pics, please post them, or better explain what this mean. Any help offered wouild be much appreciated.
thanx,
Old Jan 18, 2002 | 06:42 PM
89HF's Avatar
New User
Default Re: HELP!!!!, with hcp (iwhichisme)
OK-the part of your fr crossmember that the motor mt bolts into has two tabs stiking up,w/a hole in each for the motor mt bolt to go through.You will have to slot,elongate,or redrill these holes so they line up w/the fr mt(which I keep calling a mt mount,but I believe it's bolted to the tranny).I also had to trim the outside of these tabs so the mt could sit close enough to the crossmember to let me bolt it up and not rest on it,transferring more vibration to the driver.You also might want to dimple (dent)the firewall behind the r mt-my r mt rests against the firewall,transferring some vibration-and you know about denting the l framerail for alt. pulley clearance,I assume-hope this helps......
Old Jan 18, 2002 | 07:05 PM
CRX-RX's Avatar
Default Re: HELP!!!!, with hcp (89crxb16a)
Ya, you just cut off about 1/2 to 3/4" on the bracket on the crossmember, and you'll have to drill new holes for it.
https://honda-tech.com/zerothread?id=114804&page=1
YoungGunnaT
Sep 18, 2012 05:47 AM
webbs2jzgte
Jan 12, 2010 06:04 PM
_Bug_
Mar 11, 2006 08:58 PM
Herminator
Welding / Fabrication
Oct 22, 2005 04:00 PM
Trbospnkr
Feb 8, 2004 02:05 PM
