CTR cams on b16a worth it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orig1nalkhmersta »</TD></TR><TR><TD CLASS="quote">of course! ctr cams = best oem b-series cams, more agressive than itr cams</TD></TR></TABLE>
not true. 98+ itr cams are exactly the ctr cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">Yes, do it for sure man, they will make a noticable increase in power </TD></TR></TABLE>
Werd
Werd
Can anybody give me some insight on a combo I see from time to time. I hear people talk about intake CTR/exhaust ITR or vice versa. Is there any advantage of doing this? I just picked up an EF9 (b16a1) and was going to get either CTR or ITR cams with a spoon headgasket (0.45mm/0.177"???). This is what is available locally but if sk2s1 is worth the shipping (I am in Japan) I will reconsider. Thanks in advance for any help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sitinthehall »</TD></TR><TR><TD CLASS="quote">The CTR cams are infact better than the ITRs. The CTR intake cam opens 3 degrees earlier than the ITR.</TD></TR></TABLE>
You are misinformed. Please do not so boldy state fiction as fact..it confuses the newer people who are not knowledgable enough to know that you are talking out of your ***
The exhaust cams for the ITR and the CTR are the same.
OPEN: 45° before BDC
CLOSE: 10° after TDC
The intakes however, are different.
CTR
OPEN: 18° before TDC
CLOSE: 45° after BDC
ITR
OPEN: 15° before TDC
CTR
ITR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sitinthehall »</TD></TR><TR><TD CLASS="quote">The exhaust cams for the ITR and the CTR are the same.
CTR
ITR
CLOSE: 45° after BDC</TD></TR></TABLE>
I still believe you are looking at the 97-99ITR intake cam and not the 00-01. I am almost 100% postive the 00-01 itr intake cam is exactly the same as the ctr.
CTR
ITR
Totally. Great cams.
</TD></TR></TABLE>Totally. Great cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mag00n »</TD></TR><TR><TD CLASS="quote">I still believe you are looking at the 97-99ITR intake cam and not the 00-01. I am almost 100% postive the 00-01 itr intake cam is exactly the same as the ctr.</TD></TR></TABLE>
Yes, you are correct. From 00' on the ITR is the same as the CTR, so when you say that "the CTR is better than the ITR," you need to be specific about what years you are talking about. For the exhaust side...thats a different story. The exhaust cam is all the same. Back to the original topic, upgrading a B16a to a type r camshaft is a gaurenteed horsepower gain is very very cost effective, one of the best upgrades you can do
For sure I went 12's on these cams with a B16
</TD></TR></TABLE>For sure I went 12's on these cams with a B16
this is what i found. so are 00-01 itr really the same as the ctr cams? I'm confused. Who here knows the actual specs and can show proof?
http://www.allmotorhonda.com/t...s.htm
Im telling you from 2.5yrs on this site and tons of research that the 00-01 itrs are the same. I know its a fact, I dont have to prove it. If you want to waste 20minutes of your day search the archives,<FONT COLOR="green"> the truth(proof) is out there Moulder</FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotor_1320 »</TD></TR><TR><TD CLASS="quote"> yeah you should pick up those cams my stock b16 with a chip cams and gears got me 13.9 in a eg
bs
</TD></TR></TABLE>bs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spectacle »</TD></TR><TR><TD CLASS="quote">bs</TD></TR></TABLE>
Why is that BS, I went 13.6 with that WAY back in the day...
https://honda-tech.com/zerothread?id=684764
well according to this thread i found it is slightly different but you won't notice the difference at all from a 00-01 itr cam vs. ctr cam
