JDM FRONT END QUESTION IMPORTANT
i think hi beam is h1 (same as prelude)... i'm not sure. and i'm not going to dig my car out of the snow to find out
the bulb and wattage should be printed in the base of the lenses of the headlights for each light.
same as what u have now... you're gonna need to modify the socket a bit though to make it fit beacuse the jdm one is only turn signal (or just parking i can't remember) not parking/turn signal
[Modified by Benjamin Tang, 8:12 PM 1/18/2002]
yeah ive had the same problem with my turnsignals......one bulb is stuck in there and the other one i had to buy a new one.....what bulbs do you suggest and what do i have to do to modify it
Low beam = 9006
high beam = h1
fog light = h3
i recommend you put your existing socket into the corner lamp.
all you have to do is replace the rubber seal with an o-ring.
otherwise the jdm corner lamp is just a turnsignal, not a parking light.
high beam = h1
fog light = h3
does anyon eknow what kind fo latch for the hood the JDM one uses cuz i tried to put the regular one off myintegra but it didnt even come close to . uhhh using it lol thnx ... wut car can i get it from heheh ~ dude this is hard stuff ~ dayam JDM
Dongoesby
Jun 13, 2005 01:56 AM
allmotorhonda
Nov 12, 2002 08:42 AM
