LS and B20 cam difference?
Old Feb 20, 2005 | 10:19 AM
Glen Tennis's Avatar
Default LS and B20 cam difference?
Im trying to find out if LS cams are different than B20 cams. And if swapping LS cams into a B20Z wold make any difference. Anyone know?
Old Feb 20, 2005 | 10:24 AM
Default Re: LS and B20 cam difference? (Rockinfunzone)
Just did a search (D'oh!!) and found this topic posted before. The concensus is that the LS intake cam is a little more aggressive than the stock B20Z cam. Can I get some real testimony, not just opinions on this one?
Old Feb 20, 2005 | 12:36 PM
Terrible One's Avatar
obvious that ls cams are more aggressive than b20. check out the hp difference, ls = 142, b20 = 125
Old Feb 20, 2005 | 12:39 PM
hybrid_vtec's Avatar
Default Re: LS and B20 cam difference? (orig1nalkhmersta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orig1nalkhmersta &raquo;</TD></TR><TR><TD CLASS="quote">obvious that ls cams are more aggressive than b20. check out the hp difference, ls = 142, b20 = 125</TD></TR></TABLE>
No B20b is 135 hp and the B20Z is 146 hp. There is a difference but I do not think it is enough to worry about. I d go with aftermarket if I were you!
Old Feb 20, 2005 | 12:51 PM
NA425DragSter's Avatar
* B A N N E D *
b20z is better then b20b cams, b20b is the same as ls cams
Old Feb 20, 2005 | 01:21 PM
Default Re: (NA916DragSter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA916DragSter &raquo;</TD></TR><TR><TD CLASS="quote">b20z is better then b20b cams, b20b is the same as ls cams</TD></TR></TABLE>
Exhaust is the same not intake. there is a slight differnce but not enought o make a difference though
Old Feb 21, 2005 | 09:47 AM
Since there is no diffinitive evidence that the LS cam is better, I may have to find some and dyno both the B20Z and LS cams just to end this little debate....Keep posted, Im gonna get my car dyno'd soon. And I bet I can find some LS cams real quick....
Old Feb 21, 2005 | 10:41 AM
* B A N N E D *
Default Re: LS and B20 cam difference? (hybrid_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">
Exhaust is the same not intake. there is a slight differnce but not enought o make a difference though</TD></TR></TABLE> i pretty sure this is right, i remember sumthing like that my friend told me i wasn't tryin to listin,all i remember he told me is b20z had a higher lift then ls,not sure by how much ,i say keep that b20z cams in and call it aday, i wouldn;t waste my money on a dyno just for those cams unless u got other mods done already to ur motor
93_civic_hatch
Jun 19, 2005 10:32 PM
justint
Nov 21, 2004 04:18 PM
ForceFed Coupe
Mar 11, 2004 07:31 PM
Shua derson
May 13, 2003 11:20 PM
