Broken LCA bolt, Omnipower LCA swap w/ PICS!
Old Feb 20, 2005 | 05:55 AM
djmatix's Avatar
Default Broken LCA bolt, Omnipower LCA swap w/ PICS!
So I had the whole broken LCA bolt.....both sides rear. Got pissed, then I got Omnipower! I read all about people having this same problem, so didnt feel alone. Love the new LCA's, my only problem with them is that there is no place to mount the ABS metal casing like on the stock ones. Enjoy the pics!
KYB AGX, TEIN S-TECH, OMNIPOWER REAR LCA
Breaker Bar'ed the welded nut on the stock shock, Siezed bolt.
Other side, showing how the bolt broke in the bushing.
About 10 seconds with a ryobi recipricating saw, and milwakee "the torch" blade.
When you dont have a spring compressor, hog-tie the shock with a towel, turn head.
The other bolts didnt hassle me. Those abs bracket bolts were tough for little 10mm.
Old vs. New. New honda hardware and some PB blaster. Note the difference where the sway bar mounts.
closeup of LCA's, ******* siezed bushing. Like the star, even though its covered when installed.
got it mounted, shock installed.
Connected the sway bar. (you'll need a nut and lockwasher)
Done with one side, let the car down...time to do the other side!
Done! oooh looks nice!
Slanted tuner mag shot. haha
The new bling.
tanabe hyper medallion shooting exhaust at me.
Dad's lexus, honda integra , and 4-dr ls for when the teg is down.
GSR blades, w/ SI centercaps.
Modified by djmatix at 10:20 AM 2/21/2005
Modified by djmatix at 6:03 PM 2/21/2005
Old Feb 20, 2005 | 07:47 AM
chero112's Avatar
Default Re: Broken LCA bolt, Omnipower LCA swap w/ PICS! (djmatix)
nice work bro........ How long did it take you to do?
Old Feb 20, 2005 | 07:52 AM
Chris_Bye's Avatar
Default Re: Broken LCA bolt, Omnipower LCA swap w/ PICS! (chero112)
looks nice man
...same bolt broke for me
Old Feb 20, 2005 | 09:12 AM
lak8's Avatar
Default Re: Broken LCA bolt, Omnipower LCA swap w/ PICS! (Chris_Bye)
very nice, love the teg also
Old Feb 20, 2005 | 11:32 AM
djmatix's Avatar
once I had the recipricating saw purchased and the other bolts didnt seize, it took me about 45 mins a side. I'm lucky that I sprayed the **** out of the other bolts, they put up very little resistance before they started to back out. The suspension is so simple on these honda/acuras. I used to think it would be such a task to put rear discs on a civic. Thanks for the feedback!
Old Feb 20, 2005 | 12:56 PM
Pythagoras's Avatar
nice...I have some omni LCA sitting in my room waiting to go in
Old Feb 20, 2005 | 01:39 PM
KOALA YUMMIES's Avatar
Default Re: Broken LCA bolt, Omnipower LCA swap w/ PICS! (Pythagoras)
That star that they designed into it is so stupid. Its a freaking "Emo" LCA as one of my friends said.
Old Feb 20, 2005 | 01:44 PM
Greenery18's Avatar
Default Re: Broken LCA bolt, Omnipower LCA swap w/ PICS! (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">That star that they designed into it is so stupid. Its a freaking "Emo" LCA as one of my friends said. </TD></TR></TABLE>
Isn't it also true that the omnipower LCA's don't even save any weight over the stock units, unlike the SRR ones... ? I heard this somewehre online
Old Feb 20, 2005 | 02:10 PM
Pythagoras's Avatar
How the hell do you make a correlation between a star and being emo?
Old Feb 20, 2005 | 02:16 PM
jdmsiR20's Avatar
good work and i love the star... u need a little uniqueness anyway...
i broke both bolts too and the car is goin into the shop tomorrow to get it fixed
Old Feb 20, 2005 | 02:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pythagoras &raquo;</TD></TR><TR><TD CLASS="quote">
How the hell do you make a correlation between a star and being emo?</TD></TR></TABLE>
Because I just do, thank you.
Old Feb 20, 2005 | 02:44 PM
Pythagoras's Avatar
Because I just do, thank you. </TD></TR></TABLE>
you should stop listening to your friends i guess
Old Feb 20, 2005 | 02:58 PM
SilverDc2's Avatar
SRR owns man....omni power looks good too....
i wonder if these fade....mine haven't faded much but my friend EK have faded quite a bit.
Old Feb 20, 2005 | 04:21 PM
Gerbilo's Avatar
Default Re: Broken LCA bolt, Omnipower LCA swap w/ PICS! (SilverDc2)
Very nice! I broke the same bolt when doing my suspension, it was a helluva time getting it out but we finally did. The LCAs are nice though, how much did they run you?
Old Feb 20, 2005 | 06:27 PM
djmatix's Avatar
I got them through robear racing. 109 with free shipping. Although I called them up and had them rush them to me because i can only work on my car during the weekend. Real nice guys, always answer the phone.
http://www.robearracing.com/pd_omnipower_lower.cfm
also, my sister saw the omnipower LCA's and she said "those are SOOOO EMO" hahaha
Old Feb 20, 2005 | 06:31 PM
vtec69's Avatar
those are soooo sexy
Old Feb 20, 2005 | 07:30 PM
Dngerzone2's Avatar
Default Re: Broken LCA bolt, Omnipower LCA swap w/ PICS! (vtec69)
not feeling the star on the lca but whateva...what lip is that? looks CF
Old Feb 20, 2005 | 08:17 PM
Mattyg2's Avatar
how did u get the broken bolt out the lca?
Old Feb 20, 2005 | 08:24 PM
Phantastic's Avatar
Default Re: Broken LCA bolt, Omnipower LCA swap w/ PICS! (jdmsiR20)
nice job and ride height
Old Feb 20, 2005 | 11:55 PM
riceball777's Avatar
looks very nice
Old Feb 21, 2005 | 04:49 AM
97CWITR's Avatar
Default Re: Broken LCA bolt, Omnipower LCA swap w/ PICS! (riceball777)
Looks good!
Hoping to do this install, along with some of their coilovers very soon!
How was the fitment?
I'm concerned with how you ran your lines under your shocks...
Old Feb 21, 2005 | 06:17 AM
djmatix's Avatar
Default Re: Broken LCA bolt, Omnipower LCA swap w/ PICS! (96BLkGSR)
the fit was perfect, a direct replacement. The abs lines run undernieth the shock on the factory control arm.
I didnt get the bolts out of the other control arms, I just cut the bolts off and chucked the arms.
I had to put a jack stand under the arm and lower the car onto the stand to get the rear sway bar to bolt up, but it was simple.
also, the lip is carbon fiber. It's an ITR replica lip. I got it from brian wong aka b18c1_powered_si . Really good seller and has quality parts. The lip was from japan.
Old Feb 26, 2005 | 02:57 PM
b18c4door's Avatar
What are the bushings on the omnipower made of? Urethane or rubber? Can they be replaced when they wear out? My LACA's bushings have taken a dump on me and squeak like *****. I figure I will replace the LCA along with suspension at the same time. Thanks!
Old Feb 26, 2005 | 03:49 PM
WhoisDan's Avatar
Default Re: (b18c4door)
The Star and the Doggy Bone is the Hotness.
Old Feb 26, 2005 | 05:20 PM
uzabatty's Avatar
very nice~!!!
