my DIY wideband lambda - what values should I get?
Old Feb 20, 2005 | 03:00 AM
petrv's Avatar
Default my DIY wideband lambda - what values should I get?
I have built my DIY wideband lambda sensor and now I need to check if it runs accurate enough. What values of AFR (or lambda) should I expect on stock Hondas:
1) at idle
2) when cruising with little throttle, constant speed
3) at full throttle?
Second question, where should be the sensor located? So far, I have put the sensor into my muffler tip and at idle, the sensor showed lambda 0.99 - 1.00 (AFR 14.7). Is this OK for idle?
Old Feb 20, 2005 | 03:10 AM
DutchITR1689's Avatar
Default Re: my DIY wideband lambda - what values should I get? (petrv)
Lambda should be 1 for idle and part throttle.
For full throttle a bit richer, but that depends on your mods.
How did you build your own lambda sensor?
Old Feb 20, 2005 | 03:23 AM
petrv's Avatar
Default Re: my DIY wideband lambda - what values should I get? (DutchITR1689)
I need to know some average values at wot for STOCK hondas.
Well, I work with electronics, so this was my home project. I have used Bosch LSU4 sensor.
Old Feb 20, 2005 | 07:37 AM
cjames235's Avatar
i would move the sensor up farther in the pipe like into the header collector........ if you have a cat in the exhaust you want the sensor before the cat..... if you have a test pipe you can put it in either the test pipe or the header collector
Old Feb 20, 2005 | 07:44 AM
petrv's Avatar
Default Re: my DIY wideband lambda - what values should I get? (cjames235)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjames235 &raquo;</TD></TR><TR><TD CLASS="quote">i would move the sensor up farther in the pipe like into the header collector........ if you have a cat in the exhaust you want the sensor before the cat..... if you have a test pipe you can put it in either the test pipe or the header collector</TD></TR></TABLE>
Does the cat really change the O2 amount in the exhaust gas?
petrv
Feb 22, 2005 08:19 AM
ion_four
Sep 23, 2003 12:28 PM
tegtyper
Jun 13, 2003 11:15 AM
