h22 turbo clearence - front mount bracket/block wings?
im having some problems mounting my manifold, its the 'ss autochrome style' manifold with a garret t3/t04e turbo. i already had to grind a good bit of the front mount, but need just a bit more, and not to sure how much of it can give. also the little wings on the block are gonna have to go. will it hurt anything?
You can remove the block webbings using an angle grinder. Just don't remove too much otherwise you'll be SOL. Use your good judgement on how much is too much.
eksleeper97
Sep 2, 2013 09:02 AM
Firedrake
Sep 30, 2002 02:05 PM
