camshaft lube?
Old Feb 20, 2005 | 01:27 AM
an2ny888's Avatar
Default camshaft lube?
im about to install my spoon cams... what do you guys use for cam lube? i'm in the philippines so i don't really have access to the special cam lubes available in north america. any substitutes i could use?
Old Feb 20, 2005 | 01:33 AM
Kendall's Avatar
Assembly lube gets the job done, but I usually coat the cams in motor oil before I put them in regardless of the cam lube I use.
Old Feb 20, 2005 | 04:05 AM
Finland's Avatar
I've always used cam lube with new cams. I get it from my local parts store. You should be able to find it somewhere in your country.
Old Feb 20, 2005 | 04:41 AM
non-VTEC's Avatar
Default Re: camshaft lube? (an2ny888)
if you cant find any engine assembly lube use some thicker engine oil for pre-lubing the cams........it should be ok....
Old Feb 20, 2005 | 05:59 AM
Eva01's Avatar
Default Re: camshaft lube? (non-VTEC)
I would recommend some cam lube or assembly oil. I happened to find some after looking in 3 Autozone stores. But I think the one store just had it by serendipidy.
Old Feb 20, 2005 | 06:06 AM
jakeiscool's Avatar
Banned
Motor oil
DFW
Feb 24, 2007 05:09 PM
BIG RICH
Aug 15, 2003 04:33 PM
civicracer1993
May 19, 2003 06:07 PM
toooslow
Apr 10, 2003 11:41 AM
1.8Tities
Sep 25, 2002 04:47 PM
