what head gasket for CTR pistons into b18c?
Old Feb 19, 2005 | 11:42 PM
neeks's Avatar
Default what head gasket for CTR pistons into b18c?
i just bought a stock head gasket for my gsr that has ctr pistons in it...
you think itll hold up or should i get another one??
and yes i searched =P
Old Feb 20, 2005 | 12:24 AM
reactiondc2's Avatar
Default Re: what head gasket for CTR pistons into b18c? (neeks)
it will hold up but i hope you are planning on race gas cause your compression is gonna be up there a lil ways
Old Feb 20, 2005 | 01:09 AM
neeks's Avatar
Default Re: what head gasket for CTR pistons into b18c? (reactiondc2)
err i was hoping on 87 octane @ rotten robbies =x
Old Feb 20, 2005 | 02:47 AM
THEUSED's Avatar
87 Octane + CTR Pistons = Detonation
Old Feb 20, 2005 | 10:47 AM
neeks's Avatar
Default Re: (THEUSED)
dammit!
ok so its safe to say that the stock head gasket will be cooL as long as i use premium gas...
buuuuuut in the long run itll be cheaper to buy a thicker/aftermarket head gasket and spend a little less on gas...
so which one would you recommend?
thanks for your replies btw
Old Feb 20, 2005 | 12:27 PM
THEUSED's Avatar
CTR's in a GSR will yeild around 12 to 1, with a stock headgasket, your best bet would be to run ITR's which yeild about 11.4:1 but you'd stilll need to run some good gas, aren't stock GSR's suppose to take like 89 or higher?
Old Feb 21, 2005 | 06:36 AM
he should read the post about the compression ratio of ctr pistons...its right on top in the all motor forum...if i remember right the compression ratio with ctr's and a p72 head is like 12.5 or higher
Old Feb 21, 2005 | 01:48 PM
Katman's Avatar
a stock head gasket will work.
If you want to lower your compression a little, try a thicker than stock headgasket by Cometic.
HamiltonRex
17
Feb 15, 2005 08:49 AM
awdriscol4
Jan 7, 2005 06:35 PM
TheOne
Dec 11, 2003 06:19 PM
Propulsion
Nov 3, 2003 09:30 AM
Teepo
Nov 7, 2002 08:28 PM
