How to remove hub?
Hey guys.. I guess i'm just going to take my entire hub off and then take it to a shop and have the ball joint pressed out cuz I can't get my hands on a pressing kit and I dont feel like payin hundreds of bucks for something i'm only doing once... (hopefully)
I know how to get most everything off but my only question is the hoses that are connected to the entire thing. I believe theyre brake lines. If I can take off those wires then I know how to get it off but that really is the only issue i'm having.
Anyone have some illustrations or pictures that will show me how to do it?
I just realize I might be calling it the wrong name. I'm trying to get the entire thing that has the ball joint on it off. I think its called a hub? Iono, Brake assembly? I duno whatever its called I need it off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Beast »</TD></TR><TR><TD CLASS="quote">I just realize I might be calling it the wrong name. I'm trying to get the entire thing that has the ball joint on it off. I think its called a hub? Iono, Brake assembly? I duno whatever its called I need it off
Its called the Knuckle,
remove the brake caliper and mount, then take off the rotor, then remove the tire rod, then the axle( remove the axle nut ) then disconnect the lower ball joint from the lower control arm, then the upper ball joint. and wala it comes out.
</TD></TR></TABLE>Its called the Knuckle,
sorry i dont know the answer to you question but i did think of something that may be useful to you... instead of taking it to a shop to do you could go to Kragen and just rent the ball joint press and then return when your done... i think it costs like $6 a day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing »</TD></TR><TR><TD CLASS="quote">Its called the Knuckle,
remove the brake caliper and mount, then take off the rotor, then remove the tire rod, then the axle( remove the axle nut ) then disconnect the lower ball joint from the lower control arm, then the upper ball joint. and wala it comes out.</TD></TR></TABLE>
ooh okay, so are those hoses connected to the brake caliper?
EG2Driver
Jun 6, 2006 08:50 PM
copperfox
19
Jul 19, 2005 09:52 PM
