pr3-3 question
Old Feb 19, 2005 | 08:48 PM
Matty's Avatar
Default pr3-3 question
my head is stamped pr3-3 some people are telling me this is a type r head and some an sir. can anyone clarify this for me
Old Feb 19, 2005 | 09:16 PM
ITR#132's Avatar
What does your block say?
Old Feb 19, 2005 | 09:27 PM
itralex's Avatar
Default Re: (ITR#132)
if you have the head off, look inside the ports and you should see that the ports are polished near the seat and no where else
Old Feb 19, 2005 | 10:22 PM
Kendall's Avatar
The digit after the dash in the head stamp is nothing but a random digit between 1 and 4. It has absolutely nothing to do with what the head actually is. I've seen Type R heads with every digit from 1 to 4, and regular B16 heads with every digit from 1 to 4. Also, I've seen P72 heads with every digit from 1 to 4.
Cliff notes: The last digit means nothing and those who aren't aware of that fact shouldn't be making false claims.
Old Feb 19, 2005 | 10:25 PM
Matty's Avatar
i got the motor used, the blosk is a b16a2. the head is off though ill check the insides
thanks
Old Feb 20, 2005 | 04:44 AM
non-VTEC's Avatar
Default Re: (Matty)
chances are its just a normal B16 head if it came off a B16A block.
the only way to tell if its a ITR head is to tear it apart and look in the intake ports to see if there has been some "light" porting near the valve seats.
Old Feb 20, 2005 | 08:31 PM
ITR#132's Avatar
Default Re: (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
the only way to tell if its a ITR head is to tear it apart and look in the intake ports to see if there has been some "light" porting near the valve seats. </TD></TR></TABLE>
Look at the intake valves Also, dont need to tear anything apart to see the porting.
ninjaturtle1023
Jul 26, 2004 06:32 AM
Home Skillet
Dec 6, 2003 09:43 AM
johnzm
13
Sep 29, 2003 04:42 AM
93B17A
Jun 9, 2003 07:27 PM
hatchii
May 6, 2003 09:30 PM
