misfire dealer cannot fix it
I just have someone did a swap of a 2001 gsr into 2000 Lx civic. I use the 2000 si harness and 2001 gsr ecu. Random misfiring in 4 cylinder. Change the ignition wire. spark plug. distrubitor, and fuel regulator. Check the fuel pressure, injectors, map sensors, no problem with them. Then take it to the acura dealer and have valve adjustment. Still did not fix the problem. Don't know what to do. Need some serious help. Thanks
is the "valve adjustment" all the acura dealer did????did u tell them there was a random misfire in cyl 4? id recheck ur wiring....u never know.
dayaftertomorrow
11
Feb 20, 2005 05:54 PM
