timing belt quesion for my B20
Old Feb 19, 2005 | 06:48 PM
erebunicrx's Avatar
Default timing belt quesion for my B20
i want to get a timing belt kit for my B20 and was thinking about going with a typer water pump. my question is can i just a typer timing belt kit? i thought that the b18a/b was the same as the b20 but the prostreet site wanted $30 more.
Old Feb 19, 2005 | 07:12 PM
CHEETAH's Avatar
Default Re: timing belt quesion for my B20 (erebunicrx)
if you use an itr 22 teeth wataer pump then the gsr/itr power enterprise or toda racing belt will work ... you will have to use a gsr/itr belt with 22 teeth pump, if you retain the 19 teeth ls/b20 pump then stick with ls/b20 timing belt (no aftermarket belts available).
greg
Old Feb 19, 2005 | 07:18 PM
erebunicrx's Avatar
so i can fit the itr water pump and timing belr no problem? im just using oem
Old Feb 20, 2005 | 08:15 AM
erebunicrx's Avatar
ttt
Old Feb 20, 2005 | 08:19 AM
Big Teggie's Avatar
Default Re: (erebunicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erebunicrx &raquo;</TD></TR><TR><TD CLASS="quote">so i can fit the itr water pump and timing belr no problem? im just using oem</TD></TR></TABLE>
Yes
Like Greg said....
22T Water Pump=GSR/ITR Timing Belt
19T Water Pump=LS/B20 Timing Belt
Old Feb 20, 2005 | 08:31 AM
erebunicrx's Avatar
ok thanks
Fook_me_honda
Mar 27, 2010 11:54 AM
ekturbohatch22
May 11, 2007 07:25 PM
Scorchin Civic
Mar 1, 2006 05:25 PM
1SickHb
Oct 4, 2005 09:00 AM
THE GAME IS THICK
Feb 5, 2003 10:56 AM
