Someone stole my distributor and wires... doh
Old Feb 19, 2005 | 05:30 PM
28's Avatar
28
Default Someone stole my distributor and wires... doh
So I bought this theft recovery 98 Civic EX. It came with no distributor or wires or airbox/tubing
I have a couple 97 DX and LX parts cars, will the distributor and wires work from the non-vtec cars or not?
also what has to be done to time it after I install... any tips help.
Old Feb 19, 2005 | 05:46 PM
GdmLaz's Avatar
no they won't work the non-vtec distributors don' line up u'll only be able 2 screw like 2 bolts in
Old Feb 19, 2005 | 06:50 PM
28's Avatar
28
Default Re: (Slammed92hbonN20)
damn... where should I look to buy a new one?
Old Feb 19, 2005 | 11:39 PM
28's Avatar
28
Default Re: (28)
so the distributor will not work... will the wires work?
also what has to be done to time the engine ?
Old Feb 19, 2005 | 11:41 PM
Br1anPham's Avatar
Default Re: (28)
If you already ahve the distributor, why dont you try it. Im sure your d16y7 distributor will work with the d16y8 Ex motor. The plug wires will definatly work for sure.
Old Feb 20, 2005 | 07:16 AM
28's Avatar
28
Default Re: (Br1anPham)
any info on timing it?
I just haven't put it on because I wanted to get some opinions first...
Old Feb 20, 2005 | 07:22 AM
Tiferet's Avatar
Default Re: Someone stole my distributor and wires... doh (28)
The Y7 and Y8 distributor's are the same.
Old Feb 20, 2005 | 07:41 AM
EK k kay's Avatar
Default Re: Someone stole my distributor and wires... doh (L.D.S. Construction)
I had a y7 motor and did the mini me and put a y8 head on the block. I used the y7 dizzy and spark plug cables and it works fine.
Old Feb 20, 2005 | 09:25 AM
28's Avatar
28
Default Re: Someone stole my distributor and wires... doh (chowmien)
what kind of timing is needed to install ?
Old Feb 20, 2005 | 10:04 AM
GdmLaz's Avatar
i had an ex motor and i went to the junkyard and bought a dx distribut and the holes din't line up at all the wires will work tho
Old Feb 20, 2005 | 07:10 PM
28's Avatar
28
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 &raquo;</TD></TR><TR><TD CLASS="quote">i had an ex motor and i went to the junkyard and bought a dx distribut and the holes din't line up at all the wires will work tho</TD></TR></TABLE>
what year car did you pull it off of?
Old Feb 21, 2005 | 08:42 AM
28's Avatar
28
Default Re: (28)
bump
hOnDaGrL03
Jun 1, 2006 04:31 AM
Honda_18
Nov 27, 2004 10:07 AM
SOHC_MShue
Oct 19, 2003 01:54 PM
SOHC_MShue
Oct 6, 2003 10:05 AM
the DR.
Feb 2, 2002 04:38 AM
