cluster, tail, corner lamps, went out
Old Jan 18, 2002 | 02:54 PM
wreckedagain's Avatar
Default cluster, tail, corner lamps, went out
Yesterday my corner lamps, tail lights, and instrument cluster went out, so I check the fuse and it was good, and then checked the relay fuse and its good too. Anyone know where the actual relay is, and could that be the problem. Or maybe its grounding out some where, i already ran a search and came up empty handed.
Thanx for any help
Old Jan 24, 2002 | 06:54 AM
WOTTEG's Avatar
Default Re: cluster, tail, corner lamps, went out (wreckedagain)
Does your speedometer not work?
I had a fuse go out and the speedometer quit working. THere are like 3-4 fuses related to the instument panel. I (hope this is correct) remember it being fuse 42 that went out.
Check ALL your fuses, even the ones in the engine bay by the battery.
Good luck,
Karl
Old Jan 25, 2002 | 05:17 PM
Default Re: cluster, tail, corner lamps, went out (WOTTEG)
know i found the problem, it was a wire in the steering column it just got burnt to poo poo, i suppose it got a kink in it at some time or another...
timntam
Feb 3, 2006 11:10 AM
Streetdreams022
Jan 8, 2005 08:20 AM
DC2Hybrid1
Jun 6, 2004 08:55 PM
mrbsponge
Dec 31, 2003 03:31 PM
smeister
May 24, 2002 04:09 PM
