Need to Know if I can use a VX tranny to a B16A2 motor 92civic hatch
Old Feb 19, 2005 | 03:39 PM
circuitcivic's Avatar
Default Need to Know if I can use a VX tranny to a B16A2 motor 92civic hatch
I need to know if I have to buy the complete swap or save some money and use the vx civic hatchback of the 92 to a B16A2 motor, is a good combination or bad, regular please help me...
Old Feb 19, 2005 | 03:43 PM
dwnthehatch's Avatar
Default Re: Need to Know if I can use a VX tranny to a B16A2 motor 92civic hatch (circuitcivic)
No. A d series tranny will not work on a b series motor.
Fu_kJDM's Avatar
D series to D series parts only. B series to B series parts only.
D series VX tranny to B series motor isnt compatible.
HATCHingMN's Avatar
NO...
if you have a B series MOTOR, you need B series transmission.
the VX tranny is from a D series so it will not fit or bolt in.
Old Feb 19, 2005 | 03:48 PM
komat's Avatar
Default Re: Need to Know if I can use a VX tranny to a B16A2 motor 92civic hatch (HATCHingMN)
that be pointless to have the b16 with the vx tranny
even if it was possible
Old Feb 19, 2005 | 03:51 PM
OK thanks to all replies
Old Feb 19, 2005 | 03:58 PM
Using your experiebce with honda civics wich one is the best motor for a circuit racing, B16A2-B18C-B16B or B18C5 to swap in to my VX 1992 civic hatch???
Old Feb 19, 2005 | 03:59 PM
Fu_kJDM's Avatar
more powa b18c5 holla
no but seriously.
Old Feb 19, 2005 | 04:02 PM
HATCHingMN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by circuitcivic &raquo;</TD></TR><TR><TD CLASS="quote">Using your experiebce with honda civics wich one is the best motor for a circuit racing, B16A2-B18C-B16B or B18C5 to swap in to my VX 1992 civic hatch??? </TD></TR></TABLE>
the B18c5 from the Integra type R
cost $$$$4K-5k though
Old Feb 19, 2005 | 04:04 PM
B18C5 good answer, but too expensive "is HOLA" one L
thanks
Old Feb 19, 2005 | 04:07 PM
How much is the charge to perform a swap in the United States??
Old Feb 19, 2005 | 04:14 PM
turbohondaboi's Avatar
I am actually going to attach a D series tranny to B series motor pretty soon. I sure someone has done it before if not I will be the first. In order to do it you need to make an adapter plate for the tranny to the motor, then you will need a custom flywheel causae the bolt pattern is different, when you drop the motor into the car you will need custom mounts (maybe??). All this is just not worth the cost and time because be much cheaper and easier to find a B series tranny. D series tranny and axles are not as strong as B series.
Still you may think y go through all this trouble, few ++ are long gears( ever cruise your B series hatch on the freeway going 70 mph in 5th just under 4500 rpm for Hours on end.) should make your motor going 70mph @ under 3k just a little happier and your wallet, another real Big plus is the extinction of B series trannies , when Guys with B series will give away there D series tranny. D tranny are everywhere and real cheap if you blow it. My opinion may not be credible because this is my 2 post , but still love my honda.
Old Feb 19, 2005 | 04:49 PM
GdmLaz's Avatar
hmmm that'll be somethine this sounds 2 me like the sohc with the dohc head a total waste of time it came out to be slower than before
Old Feb 19, 2005 | 05:19 PM
komat's Avatar
Default Re: (Slammed92hbonN20)
yep
a waste of b16 motor i say if you try to put a vx tranny
Old Feb 19, 2005 | 05:48 PM
GdmLaz's Avatar
and anyways isn't the vx tranny pathetic like the guears are made for economy damn bro atleast an ex tranny lol
KDL323
Jan 29, 2008 03:05 PM
TXGrunt
13
Dec 13, 2007 11:57 AM
BIG T
Jul 3, 2007 12:56 AM
baozer
Oct 30, 2006 06:08 PM
ShortbusEK
Apr 23, 2002 03:21 PM
