jdm EG6 Front brake setup
Would the jdm eg6 front brake conversion bolt on to a 93 civic hatchback.Is the front brakes the same size as the integra ls,gsr and civic ex brakes.Would it be a good idea to get the MS and the BB when doing this set up.
Modified by racerus at 3:39 AM 2/20/2005
Fortunatly somebody was just asking about the brakes on their EG6 front clip. Here is what we found out:
EG6 has 10.2" rotors just like integras
EG6 has larger Nissin Calipers just like integras.
EG6 has same calipers as the 93-95 Civic EX 2dr NON ABS (not same piston size as integras).
EG6 has 7/8" master cylinder just like 93-95 Civic EX 2dr NON ABS.
If you purchase EG6 front brakes, you will need to get the Master Cylinder from a USDM 93-95 Civic EX 2dr NON ABS (7/8")
oroca
Mar 20, 2009 07:25 PM
