F22A Hybrid
Old Feb 19, 2005 | 03:10 PM
newbiehonda_05's Avatar
Default F22A Hybrid
My friend can get a hold of a head from a VTEC accord at a junkyard. He was wondering if this head swap is a good way to get some performance out of his engine. He also wonders what his compression would be after he does the swap.
Old Feb 19, 2005 | 06:52 PM
TxTuner
Guest
Posts: n/a
Default Re: F22A Hybrid (newbiehonda_05)
The only thing you get out of the swap is VTec. You want big gains.... boost the stock non-vtec F or swap in an H22/23
Old Feb 19, 2005 | 08:25 PM
Default Re: F22A Hybrid (TxTuner)
I know I can boost or do a H22A swap, but that's not the question. I was also wondering if it would fit easily and what the compression ratio would be. thanks
Old Feb 19, 2005 | 08:29 PM
kniob's Avatar
I assume it can be done, but don't know if it will be worth the extra 5hp and the big empressive vtec
Old Feb 19, 2005 | 08:33 PM
Default Re: F22A Hybrid (kniob)
I will do my own port and polish and get a camshaft from Gude so, ya it would be worth the few hp. And plus that I am getting a custom 2.5" exhaust done soon.
Old Feb 19, 2005 | 09:22 PM
accordselux's Avatar
Me Gusta History
You must be a newbie honda or you wouldnt get Gude.
Try Web Camshafts. Gude ahs a bad rep here on h-t.
Old Feb 19, 2005 | 10:02 PM
So does any one know what the compression would be?
Old Feb 20, 2005 | 09:27 AM
Default Re: (newbiehonda_05)
One more thing, do I have to do the same thing with SOCH like LSVTEC to tap a hole in the block and get a oil filter adaptor for the oil return?
Old Feb 20, 2005 | 10:56 AM
matix's Avatar
The compression should be whatever the f22b1 is. We did a f22b1 swap into my freinds car that used to be a f22b2. Its not worth it for performance in my opinion. But he had 150k miles on his f22b2 and the f22b1 had 80k wich was the reason we did it.
Old Feb 20, 2005 | 05:43 PM
TxTuner
Guest
Posts: n/a
Default Re: (matix)
Compression will be the same unless your swapping pistons
Definitely go with webcams
And what is a Single Over Cam Head?
spade1990
Jun 5, 2011 08:47 PM
92 bandit
Jun 7, 2007 04:44 PM
mandelo
Jun 23, 2004 06:07 AM
Honda Bob
10
Nov 24, 2003 12:23 PM
Rob03Pro5
Jul 19, 2001 10:15 PM
