Installing P28 into GSR
everything is hooked up and tuned with hondata but my question is, since it wont fit back where it is supposed to go (due to wiring and harnesses) where did you mount it and how?
pics would help greatly - Thanks
i know some of my customers have folded the wiring of the conversion harness and worked it back in place of where the stock ecu would sit...I also have seen customers lift of the carpet where the passengers feet would go, and tuck the ecu under there. Its really up to you. You might have to work it a little bit to get it where you want it
just pull up your skirt, bolt the ecu where it is supposed to go, and fold the wires. Grab the kick panel and slap it back in place. It's going to take some elbow grease and a little creativity. Dont be afraid to man-handle the things.
u could apply some velcro to the back of the ecu and it should attach to the carpeting under floormats.. just be sure to warn passengers not to play footsie with ur harness wiring..
2k_Si
11
Jan 30, 2009 07:32 AM
streetlvlhatch
Dec 26, 2003 12:59 PM
