jb weld on bov flange= good idea?
Old Feb 19, 2005 | 01:46 PM
TrueUntilDeath.com's Avatar
Default jb weld on bov flange= good idea?
i was wondering if using 2-3 tubes of JB weld on my upper charge pipe for a TurboXS RFL Flange will work. i plan to let it sit and dry for about 20 hours.
Old Feb 19, 2005 | 01:58 PM
W O T's Avatar
Default Re: jb weld on bov flange= good idea? (TurboPandaRFL)
2-3tubes?
**** man, 1tube of Steel and 1 tube of hardner will be plenty plenty more than enough
Just get the regular JB WELD and not there new JB Quick and let it cure in a room temp envirnment for 4-5 hours minimum
Old Feb 19, 2005 | 02:28 PM
Default Re: jb weld on bov flange= good idea? (W O T)
alright cool, is there a way to increase the dry time w/ jb weld?
Old Feb 19, 2005 | 02:33 PM
W O T's Avatar
They have the new JL Quick, **** dries hard in under 4min
You could use that, but I dont know anything about its strength
Old Feb 19, 2005 | 03:56 PM
oxSLEEPERxo's Avatar
jb weld is some good **** for small things
Old Feb 19, 2005 | 04:18 PM
95hatch's Avatar
Default Re: jb weld on bov flange= good idea? (oxSLEEPERxo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">jb weld is some good **** for small things </TD></TR></TABLE>
but i dont think that your bov flange falls under the category of small things.
Old Feb 19, 2005 | 04:33 PM
Default Re: jb weld on bov flange= good idea? (95hatch)
i do consider a bov flange is small stuff, read this
http://turbod16.com/viewtopic.php?t=11900
Old Feb 19, 2005 | 05:14 PM
rioninja's Avatar
JB quick seems to be lacking the strength that the original has, from my experience.
Old Feb 19, 2005 | 05:36 PM
W O T's Avatar
Default Re: jb weld on bov flange= good idea? (rioninja)
Yeah thats what I figured, I just use it to mount/close up **** though
Old Feb 19, 2005 | 06:39 PM
this is how big the flange is
its 1.25" diameter
Old Feb 19, 2005 | 06:50 PM
93turbo16's Avatar
Just get it welded.
Old Feb 19, 2005 | 07:09 PM
junkyard racer's Avatar
Default Re: (93turbo16)
hell, i have jb weld patching a hole in my block, and its the quick ****, it dried solid when it was like 30deg. outside also.
for a little over a month now, it still seems to be holding just fine.
Old Feb 19, 2005 | 07:30 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Just get it welded. </TD></TR></TABLE>
I don't see the problem in this! Go to your local muffler shop with both pieces and just say "hey can you weld this real quick" and I guarantee within 5 minutes you'll be out and might even get it for free since it'll only cost like $5 in labor! I got ALL my IC pipes welded like this an he charged me $35 bucks...just get it welded its better then JB weld that may not hold
Old Feb 19, 2005 | 07:49 PM
skunkwhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">i do consider a bov flange is small stuff, read this
http://turbod16.com/viewtopic.php?t=11900</TD></TR></TABLE>
I'm sure it will have no problem holding the flange, but then stick a bov on there and you may have issues. As stated just go get it welded, it will cost the same but it won't be ghetto.
Old Feb 19, 2005 | 08:44 PM
Quad-Damag's Avatar
Default Re: jb weld on bov flange= good idea? (skunkwhat)
i ran mine like that 1 year @ 12 psi no problems at ALL
used old school jb not jb qwek or whatever
let it dry held up great.
till i sold my kit
Old Feb 19, 2005 | 09:21 PM
adictionbass's Avatar
Default Re: jb weld on bov flange= good idea? (Quad-Damge)
jb quick sucks. just my experience.
Old Feb 20, 2005 | 03:00 AM
Syner-G-Racing LLC's Avatar
Default Re: jb weld on bov flange= good idea? (adictionbass)
just get it welded man!
any exhaust shop will do it...hell just about any shop with a welder will hook you up cheap.
Old Feb 20, 2005 | 07:50 AM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">JB quick seems to be lacking the strength that the original has, from my experience. </TD></TR></TABLE>I agree...I used it for my HKS SSQV flange last time and the damn thing kept coming off. JB Weld does not work ALL wonders!! It's more like a temporary fix until you can actually weld the part in/on.
Old Feb 20, 2005 | 12:52 PM
Bailhatch's Avatar
Default Re: jb weld on bov flange= good idea? (NVturbo)
nothing like doing a job twice because you're lazy
1baddturbosi
Dec 13, 2006 01:54 PM
94greddycivic
Apr 17, 2005 10:33 AM
Civicman86
Mar 15, 2005 05:19 PM
DubyaAye
Jan 22, 2004 09:46 AM
adhana2
Jun 2, 2003 02:16 PM
