check engine light VS maint required light???
Old Feb 19, 2005 | 01:34 PM
carlos11's Avatar
Default check engine light VS maint required light???
my maintenace required light is on, but not my check engine light... wondering what was the difference between both? thanks
Old Feb 19, 2005 | 01:42 PM
timmy8151's Avatar
Default Re: check engine light VS maint required light??? (carlos11)
A Maint Req light is just an idiot light that goes on every 7500 miles. It doesnt mean anything is wrong with the car.
A CEL means that something is wrong with the car. An error code can be pulled from a CEL.
Old Feb 19, 2005 | 03:57 PM
carlos11's Avatar
Default Re: check engine light VS maint required light??? (timmy8151)
ah!! thanks for the clarification! anyway I can make it go away other then unplugging it??
Old Feb 19, 2005 | 04:03 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carlos11 &raquo;</TD></TR><TR><TD CLASS="quote">ah!! thanks for the clarification! anyway I can make it go away other then unplugging it??</TD></TR></TABLE>
There's a button under the dash, if you're holding it when you start the car, the light goes out. It will go back on 7,500 miles after that.
TommyEp3
Jun 4, 2013 12:14 PM
pens81
Acura TSX
Mar 30, 2006 03:42 AM
escape2me
Jan 25, 2005 02:16 PM
Rick
Jul 4, 2004 08:31 AM
under_psi
Aug 16, 2001 12:50 PM
