Ball joint removal...search is down
Old Feb 19, 2005 | 12:49 PM
Chase's Avatar
Default Ball joint removal...search is down
Im having trouble removing the lower control arm from the ball joint on my friends EG and i need help of way doing it...the FAQ axle replacment thing wasnt much help on the ball joint subject.
Old Feb 19, 2005 | 01:06 PM
Chase's Avatar
Default Re: Ball joint removal...search is down (b16crxkid)
SOMEONE ANSWER
Old Feb 19, 2005 | 01:08 PM
rwcdrums's Avatar
bump...I'm wondering the same thing
Old Feb 19, 2005 | 01:09 PM
komat's Avatar
Default Re: Ball joint removal...search is down (rwcdrums)
https://honda-tech.com/zerothread?id=887859
just bookmarked it yesterday
Old Feb 19, 2005 | 01:14 PM
Chase's Avatar
Default Re: Ball joint removal...search is down (komat)
thanks komat thats exactly what i was lookin for, cuz i saw it yesterday...thanks
Old Feb 20, 2005 | 11:32 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
i just did a five lug conversion. i actually undid most of them by propane torching the end of the arm and not hitting the grease boot with the flame. if you heat it long enough (expansion), the shock spring pressure popped the arm off the joint without even hitting it . if it doesn't pop, then a slight tap gets her off.
Old Feb 20, 2005 | 11:43 PM
sockvtec's Avatar
thanks guys, we got the axle in good and everything saturday...thanks again for the help
Alcatrax30
Nov 9, 2014 05:38 AM
mark2583
Nov 30, 2007 07:46 PM
azian21485
May 2, 2005 05:48 PM
Vp Special K
17
Jan 6, 2004 02:08 PM
munscher
Jun 16, 2003 06:34 PM
