O2 Sensor cable won't reach on my new header
So I went from the stock header on my 94 CX (with the cat attached to the header itself) to a 4-1 header and cat from Kragen. Install and fit was fine, the sensor now sits farther back then original and as such the original cable won't reach. Anyone ever has this problem? No way cali smog is going to let me pass.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m i k e o n e »</TD></TR><TR><TD CLASS="quote">So I went from the stock header on my 94 CX (with the cat attached to the header itself) to a 4-1 header and cat from Kragen. Install and fit was fine, the sensor now sits farther back then original and as such the original cable won't reach. Anyone ever has this problem? No way cali smog is going to let me pass.
you won't pass smog either if that header isn't CARB approved/exempt
</TD></TR></TABLE>you won't pass smog either if that header isn't CARB approved/exempt
which one of my o2 sensors is bad?
overall obd result: fail
fault code result: fail
fault codes:p0171,p0141,
ddescription:-
p0141:O2 sensor heater circuit malfunction (bank 11 sensor2)
p0171:system too lean (bank 11)
ddescription:-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20runner »</TD></TR><TR><TD CLASS="quote">which one of my o2 sensors is bad?
ddescription:-
check your own thread, i replied to it already
ddescription:-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 »</TD></TR><TR><TD CLASS="quote">which code is it throwing? bank 1 or bank 2?</TD></TR></TABLE>
which is which cause im throwing a code on bank 1?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reconstructdead »</TD></TR><TR><TD CLASS="quote">yeah, people in indiana are dumb.
hahahahahahahaha
</TD></TR></TABLE>hahahahahahahaha
Luserkid
Oct 25, 2003 10:16 PM
