Fuel Filter Replacement Question?
Old Feb 19, 2005 | 11:26 AM
madcrossover's Avatar
Default Fuel Filter Replacement Question?
Does anyone know where the fuel filter is located on 95 Honda Civic Sedan D15b7?
I tried to search, but the search is down. Thanks for any help!
Old Feb 19, 2005 | 11:38 AM
TeamNextGenChris's Avatar
Default Re: Fuel Filter Replacement Question? (madcrossover)
on the firewall,beside the battery.
Chris
Old Feb 19, 2005 | 11:39 AM
Archidictus's Avatar
Unceasing Measure
Firewall a bit to the left of the intake manifold. It's a black canister with a fuel line running into the top for the fuel rail and one from the pump connecting at the bottom. Leave it connected to the firewall as you loosen all the lines and bolts or you run the risk of bending brackets and stripping heads.
Enjoy. That job is annoying and messy but not necessarilly difficult.
Old Feb 19, 2005 | 11:57 AM
AutoXer's Avatar
Default Re: Fuel Filter Replacement Question? (Archidictus)
Great instructions, but make sure you use a flare wrench on the bolts.
Old Feb 19, 2005 | 12:01 PM
Default Re: Fuel Filter Replacement Question? (Everyone)
Thanks Alot! Does anyone know if the AEM Fuel Filter is worth it?
Old Feb 19, 2005 | 12:02 PM
AutoXer's Avatar
I would think they would be if you want bling; other than that, probably not.
Old Feb 19, 2005 | 12:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madcrossover &raquo;</TD></TR><TR><TD CLASS="quote">Thanks Alot! Does anyone know if the AEM Fuel Filter is worth it?</TD></TR></TABLE>
i've been wondering that myself.the filter element may have the ability to flow more fuel than stock,but the problem is the stock inlet and outlet fittings-you're still limited to them.
basically,the way i see it is if you need enough fuel volume that the stock filter is a restriction,you probably need to ditch the whole stock setup and go with bigger lines and a universal inline filter.if the stock fuel line/filter system isn't a restriction to you,the AEM filter is a waste of money.
again,i have no factual proof of that,but i have to think that the small holes in the stock banjo fittings have to be restriction before the filter is.
Chris
cmwalker
Jul 12, 2012 12:10 AM
xsi-t
May 30, 2011 05:16 PM
eg:R
Mar 31, 2010 05:37 PM
I B BANGGIN
Jan 14, 2007 06:57 PM
joeymachado
Nov 13, 2003 08:11 PM
